Misunderstood User
Originally Posted by mthomas58 View Post
snoring is the most common symptom of sleep apnea. Mild to moderate sleep apnea can be virtually undetectable to self or one's partner. The issue is that frequent apnea events which can only be detected and measured via sleep study will not allow you to ever get into rem restful sleep and this can be extremely dangerous if untreated.
Get the sleep study done. I've been on cpap for 10 years now. Best thing i've ever done!
+1
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 06-19-2013, 10:48 PM
beepbeep's Avatar
Originally Posted by jcommin View Post
Go to an ENT and do a sleep study. The study can determine the degree of your apnea, If you suddenly wake up from snoring you are literately not breathing,
I have apnea and have used a machine and mask for over 10 years. I went thru (2) sinus surgeries before the machine and mask. It took some getting use to but, I sleep thru the night and it made a big change in my well being.
Good luck........
This.
Apnea can affect your heart (as well as your partner). Get it checked out so you know how much. After that, you can pick the solution according to size of your problem. Strip, somnoplasty or (in most acute cases), uvulopalatopharyngoplasty.
Thank you for your time,
Old 06-20-2013, 02:01 AM
