Virginia Rocks!
VaSteve's Avatar
Bi planes. What's the point?
I'm on vacation and someone is flying around in a biplane. Got me thinking. Does the additional wing create additional lift? Even so, Doesn't it interfere with the lift the first wing in creating? I know there's triplanes too... I've never seen one with 4... There has to be a point where the weight outweighs the added benefit. Right?
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 07-29-2013, 10:05 AM
jyl jyl is online now
jyl's Avatar
When airfoils were not efficient, you needed more wing area to get enough lift. Rather than a very long single wing, w/ structural and maneuverability issues, they used two wings. They are far enough separated to work. Today, I'm not sure what the advantage of a biplane would be.
Old 07-29-2013, 10:14 AM
Old 07-29-2013, 10:16 AM
https://en.wikipedia.org/wiki/Armstrong_Whitworth_F.K.10
Old 07-29-2013, 10:18 AM
Seahawk's Avatar
This is a good link:
Biplane vs. Monoplane
The essential issue is drag. Monoplanes have a lot less.
1996 FJ80.
Old 07-29-2013, 10:26 AM
White and Nerdy
Tervuren's Avatar
The #1 reason is strength and weight. Try picking up a 1/2"-2" cross section 30" long aluminum bar some time. Then weld an I beam out of three pieces of the same material, and try again.(If you stack those 3 on top, it will still bend like crazy)
The shorter span that comes with two wings, combined with supports making a multi-unit structure connecting the two wins, allowed for light weight, and stiff structure. Almost half the length, and connecting supports.
Shadilay.
Old 07-29-2013, 10:40 AM
canna change law physics
red-beard's Avatar
You'll need to understand something about fluids first. Lift is simply differential pressure between the upper surface of the wing and the lower surface. Faster moving fluids create lower pressures. If the wings are spaced far enough apart, there is no interference.
A bi-plane and tri-plane allow shorter wings to create lift at the same speed. Mono-planes usually need higher speeds to create enough lift to fly.
For aerobatic planes, the shorter wings allow the plane to rotate about their central axis more quickly. This improves maneuverability. A Fokker tri-plane could rotate and bank more quickly than their counter parts. However, what you loose is stability. Longer wings are more stable than short wings.
Seahawk is correct that a biplanes disadvantage is parasitic drag from the interwing structure. This could be overcome by using monoplane type internal structure and eliminating bracing. The main thing is to understand what you are trying to achieve and design for that. Nothing is for free.
James
Red-beard for President, 2020
Old 07-29-2013, 11:02 AM
B58/732
BlueSkyJaunte's Avatar
I love bipes. The first time I saw the Lionheart homebuilt my heart skipped a few beats. Sadly they're out of production so I will probably never have the opportunity to build one.
ΜΟΛΩΝ ΛΑΒΕ
Old 07-29-2013, 11:12 AM
durn for'ner
livi's Avatar
The point is they look cool.
Markus
Resident Fluffer
Carrera '85
Old 07-29-2013, 11:38 AM
Super Moderator
cstreit's Avatar
Twice as many opportunities for a plane-to-plane hookup. ...most airplanes claiming to be Biplanes are really just confused.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 07-29-2013, 11:45 AM
Bandwidth AbUser
Jim Richards's Avatar
Yep, biplanes are old-school cool.
Jim R.
Old 07-29-2013, 11:46 AM
Super Moderator
cstreit's Avatar
Is that you in the photo Jim?
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 07-29-2013, 11:56 AM
Banned
hey man, a wing is a wing
Old 07-29-2013, 11:57 AM
Virginia Rocks!
VaSteve's Avatar
LOL.
Thanks for the info.
Old 07-29-2013, 12:07 PM
Makes me wonder if there are many biplanes still produced.
I see you can still get a Pitts Special, and an Eagle here: Aviat Aircraft: Makers of the internationally famous Pitts, Husky, and Eagle models
Any others folks are aware of (outside of homebuilt)?
Old 07-29-2013, 12:17 PM
Bill is Dead.
cashflyer's Avatar
There are a few other low volume manufacturers. Here are two that I know of off hand:
WACO Aircraft Corporation - The world's only producer of NEW FAA & EASA certified open cockpit sport biplanes
Jim Kimball Enterprises
I am currently building a Steen Skybolt.
Well... not currently. Currently I am sitting on my ass in front of the computer. But I *should* be out in the shop building my Skybolt.
Old 07-29-2013, 12:58 PM
White and Nerdy
Tervuren's Avatar
This thread made me go look up the Lion Heart, and I to, was sad to find it out of production.
@cashflyer, the Pitts is the only one I'm aware of.
Shadilay.
Old 07-29-2013, 01:00 PM
Bandwidth AbUser
Yep. I'm older than dirt.
Jim R.
Old 07-29-2013, 01:03 PM
The Skybolt looks *****in'!
WACO's look beautiful - cool to know such planes are still made. However, am I the only one here that chuckled to read the YMF-5D has an IFR panel? That seems odd to me, flying IFR in an open cockpit plane . .
Old 07-29-2013, 01:05 PM
I see you
flatbutt's Avatar
what kind of bracing would that top wing require? IOW how is it secured to the frame?
