Best Product for Flushing cooling system
My restored 1953 F 100 Pick up has been sitting for 3 years.
Lots of crap in the system
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug 1984 Mercedes 500 SEC 1991 Mercedes 420 SEL 1992 Ford F-350 Dually 28' Pace Trailer |
White vinegar...which is just acid same as Prestone flush products.
. I even used this diluted w/distilled water: . http://www.homedepot.com/p/Klean-Strip-1-gal-Phosphoric-Prep-and-Etch-GKPA30220/100406369 . Nice rig...love the red.
Don . "Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence." - - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View Last edited by Don Ro; 09-12-2013 at 02:04 PM.. |
I just do an oil change on the 911. No flush necessary.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Control Group
There is some stuff the miata guys like, flush until clear with distilled water, put the stuff in, drive around, then flush and fill with your 50:50 mix or whatever. One guy suggested taking the top radiator hose off, running water into the top of the rad and just flushing it out. If you are really concerned about junk in there, maybe take the water pump off and flush it out through there.
Radiator shop will have rig to flush it out very efficiently.
She was the kindest person I ever met |
Petie3rd
is the coolant thats in the truck all rusty now?
What does it look like ? If its not rusty, I would drain it then rinse in a few gallons of distilled water, then fill will a 50/50 mix of your favorite Prestone coolant and Distilled water If it is rusty there could be issues with whatever cleaner you choose as removing the crud may cause leaks that the crud was plugging Might be a good idea to swap in a new thermostat and coolant cap
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
Anyone try this?
That's just watered-down this:
. Klean-Strip 1 gal. Phosphoric Prep and Etch-GKPA30220 at The Home Depot
Don . "Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence." - - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View |
Navin Johnson
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
And an interesting note. I read a column in the current "Octane" magazine by Jay Leno. Apparently, he's had issues with coolant over the years, and has gone to a waterless coolant because it eliminates the corrosion that you get with coolant and has an increased boiling point. I guess he'd had problems with his vehicles due to water rusting and corroding things.
Based on a quick google search, he's using Evans Waterless Coolant.
Make sure you turn the heater on when you are flushing it.
angela
Hello http://forums.pelicanparts.com/off-topic-discussions/1102514-we-lost-amazing-woman-yesterday.html |
"Evans Waterless Coolant"
~~~~~~~~~~~~~` Wonder about warranty w/my hot little turbo'd Abarth here in AZ.
AutoBahned
Since you asked:
I have no idea, but an endorsement from Jay Leno is a good thing to me. The rust and crap that you run into when using water has always irritated me. I like the idea of a lifetime coolant that has a lower freezing point and a higher boiling point.
"Have you let Charlie Sheen drive it yet?"
~~~~~~~~~~~~ No comprende...
Have some friends who use "Evans Waterless Coolant" in their moto rads.
Higher boiling point is not the only issue for a good coolant. You also have to worry about heat conductivity. A high boiling point isnt going to do anything for you if the coolant is not moving the heat around properly.
Alexander '75 911S Targa '86 951 SOLD |
AutoBahned
nice - it's a testa rossa!
