what to use to stop corrosion between alum./steel ?
I'm not talking screw threads this is on a truck camper. The camper has an anodized aluminum skin. The new lift system that I'm going to install has a steel top plate aprox. 12 " deep x 48 " wide. This top plate screws to the structure of the camper that has an aluminum skin. The steel plate is primed/painted but I want more protection to be safe. I'm thinking rubber maybe 1/16th or so thick sandwhiched between the two what do you think ? I'm not even sure where to find rubber like that ? Or is there a better solution ? Whatever I go with will be subject ( somewhat ) to weather/UV but the majority of it will not. Suggestions ?
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
how about a bituminous coating? we spec it out on our jobs. same thing. alum sheets on stainless brackets.
poof! gone |
That will get a puzzled look from the clerk. ![]() [img]http://forums.pelicanparts.com/support/smileys/draai.gif[/img
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
okay..go in and ask for roofing tar.
poof! gone |
The Unsettler
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Max Sluiter
Get that rubber in a spray can stuff they pitch on TV.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Information Junky
At 4' long, I would be more worried about the difference in thermal expansion rates (wear and/or internal stresses cycling)
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Wood Magician
Use a thin sheet of Lexan 1/32" or equivalent such as delrin etc. Or a thin sheet of rubber and just make gaskets to go between the two surfaces.
The lift will rub through the paint in less time than you think. FYI- you can buy sheets of gasket rubber at most auto parts stores. Lexan at most large hardware stores and definitely hobby stores or TAP Plastics. |
The only thing that prevents corrosion between steel screws and aluminum is complete electrical insulation between. A pracrical way to accomplish that are plastic "shoulder washers" :
https://www.google.com/#q=shoulder+washers
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
canna change law physics
I want a Plasma Rifle in the 30 Watt range...
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
How about Por 15 + a low-friction physical barrier between the two metals?
Sherwood |
Spray on bed liner???
Marv Evans '69 911E |
