This reminds me of working on a rusty car....
How far do you go with saving a tooth? Went to the dentist today to check out an uncomfortable tooth. Doctor says that I either have a cracked tooth or a tooth that the root is dying. Either way the tooth does wobble a bit. Dentist is sending me to an endodontic to drill the filling out and determine whether the tooth is cracked or not.
If cracked the tooth should be pulled and if not then a root canal can be done. Fortunately the tooth is the very bottom left anyway so it does not have to be replaced. Anybody had this before? I am tempted just to get it extracted rather than go through all this bother of probing first. Your thoughts? |
Leave it as-is, put on some clear coat to protect what's left, lower it until it scrapes on the group ("on its nuts" as it were), put some huge wheels on it and tell everyone it has "patina"
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Edministrator
Any concerns with bite mark forensics down the line?
Good post? Leave a tip! O - $1 O - $2 O - $3 |
splinted a cracked tooth in the boonies with a guitar wire (string)..
Dentist was pleased and capped/saved it.. your gonna lose teeth down the line.. and this could be the one you need to wear dentures comfortably.. Rika |
Edministrator
Dentures good for play dates. You get a goofy second set from Mexico.
You likely have a choice of pull it for a couple of hundred and live with no tooth there, or a root canal. Root canal will be over a grand and then you need a crown for another $1,200. It depends on how much you are will to pay for chewing.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Speaking of rusty cars. .... Found this today inspecting a 2005 Malibu. Steering rack mount rusted away. I also was able to remove the sway bar mounts from the frame without unbolting them.
![]() Good luck with your tooth !
No left turn un stoned |
Her teeth are like stars....they come out at night.
Edgar 1984 Porsche 944 bone stock 1995 Mercedes E320 wagon 1970 Honda CB350 mint!!! |
Bill is Dead.
Solid food is over-rated.
Booze don't require no teef.
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
Jb weld, duh...
Recreational Mechanic
Depends on how extensive the fracture is. Your endodontist may be able to see the extent down the microscope but would have to be actually doing the root canal to see it. Cone beam CT may show it (I have one in my office) but I find it does not always show up clearly unless there is alot of bone loss around the fracture. Vertical fractures can show clinically as an isolated periodontal defect on an otherwise periodontally healthy tooth. Overall early root fractures can be very difficult to correctly diagnose. I would get the endodontist opinion and go from there. For me, these days, if there is a long term prognosis question then you're better off to consider an implant replacement now rather than after spending $$$ for a root canal and crown only to find out in a year or two that the tooth was fractured in the first place.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
I had acouple of bad teeth two years ago. One just broke off and the other was infected and needed at least a root canal. I checked out prices and found implants plus crown are about the same price as a root canal plus crown, Maybe a little more. I decided for the implants. All done now, look great, work great. I think the advantage is if something happens to the crowns they can be replaced easier because they are screwed onto the implants.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
Eva
Won't buff out? C'mon...
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
Thanks Nick.
Burn the fire.
What was the total out the door? Facing a similar situation...
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
mechanic by night
I had a lower right, aft most molar implanted for a crack situation. Yes it takes a few trips to the office over about 6-8 months if I recall. Personally the implant was not a big deal.
Tooth pulled and some bone chips installed in the resulting hole I refer to them as magic bone dust. chips have to ossify? From that point on it is just like normal thread installation. Insert installed with a healing cap. Pin installed for impressions as a locating post. Tooth made and installed. Might be forgetting something but I think it was all very interesting. I'm the guy who wants a mirror to watch the doc do the work. Not always possible but I want to see. A plus is the dentist has some cool tools. The neatest was a 4 inch deflection beam torque wrench. I want one...I dont know why. I would never use it but it is still cool.
76 911 "The Blond B_ch" (what the wife calls it) 09 Mazda 3 06 subaru legacy spec B 91 track miata |
If you are talking about a lower second molar then I generally agree. Most people chew and function fine with a first molar bite provided the rest of the arch is intact and you have a normal molar alignment (referred to as a class 1 occlusion). Second molars are often referred to as "luxury teeth".
