Eva
911SauCy's Avatar
New to us Cayenne, drivesaft issues included!! PLEASE CHECK THIS OUT
Hey All,
I've done quite a bit of research and have narrowed everything down to 2 solutions, I'd greatly appreciate your experiences or opinions on this.
PROBLEM: Driveshaft center support bearing has failed, torn rubber piece, common problem on the Cayenne, Audi Q7, and Toureg.
NOT IN QUESTION: Bringing it somewhere to have everything torn apart, driveshaft rebalanced, and getting porked for $1500+
SOLUTIONS:
1:SEE LINK BELOW AS IM LEANING THIS WAY: Cayenne Drive Shaft Clamping Bearing Support Mount: Drivetrain &amp Drive Shafts
2:Yank the current driveshaft out, pay the corecharge, and install a whole new driveshaft including the bearing support that will be a matter of time before it fails again.
Both solutions are less than $500 and within $100 of eachother...thoughts!?
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 10-06-2013, 01:06 PM
Information Junky
island911's Avatar
Ya mean Porsche Cayenne (2003-10) - Transmission - Page 2
Old 10-06-2013, 01:40 PM
Eva
911SauCy's Avatar
^^in fact I DO!
And that link just saved me $60
Old 10-06-2013, 01:46 PM
Hell Belcho
Nostril Cheese's Avatar
You can use the clamping bearing. Takes 30 minutes to do if you have an angle grinder to cut through the old bearing housing.
Super easy and cheap. Use good jackstands.
Replace the flex disc at the same time.
Old 10-06-2013, 02:42 PM
Eva
911SauCy's Avatar
Flex disc is on the transfer case or rear end side (only asking as I'm not currently under the car)
I'm sure the electric impact wrench will be invaluable on this job
Old 10-06-2013, 04:07 PM
Hell Belcho
The flex disc is in front of the center bearing, right out of the transfer case. Big rubber donut looking thing.
Old 10-06-2013, 04:19 PM
Did you get the memo?
onewhippedpuppy's Avatar
Use Pelican over Vertex all day long, my dealings with Vertex have been sketchy at best.
‘07 Mazda RX8-8
Old 10-06-2013, 04:28 PM
Eva
911SauCy's Avatar
I am really glad Pelican has this stuff, aside from my bias, Vertex has less than consistent reviews.
Old 10-07-2013, 05:38 AM
Mike80911's Avatar
I used the rebuilt shaft first time around. Bearing lasted about 10,000 miles before giving out again. Just replaced it with the clamping shaft. Very easy job took under an hour been about 3 months so far so good
89 930 Cab Black
11 Cayenne
Old 10-07-2013, 06:16 AM
