JW Apostate
I have a nice set of lightweight aluminum 3 piece wheels I will be assembling soon.
Most people use the round headed hex bolts. I like that look, but I don't want to spend $100 on hardware. I can get 80 bolts and nylock nuts for less than $15. What torque do people use and what is the recommended sealant for the wheel halves? Thanks! KT
'74 914-6 2.6 SS #746 '01 Boxster |
another round please
If you are using new bolts, torque them about 44 fpt. If reusing old bolts, torque 20-25 fpt. There are few good videos on youtube, type refinishing wheels. Also GE brand silicone sealant, #5000.
Getting old is not for wimps. |
I used an in/lb torque wrench on my BBS wheels. More accurate, but I can't remember the specs.
Do the fasteners you want have the correct length smooth shaft? Are nylocks typical? My wheels used a rubber gasket on an aluminum ring, but I ran a bead of high temp RTV on the inside for insurance. I'm just leary in not using good hardware on my wheels. Last edited by A930Rocket; 12-18-2013 at 06:29 PM.. |
JW Apostate
The bolts I want to use are 1/4", grade 8.
Threaded all the way, not smooth. 44 ft pds seems a bit high. A friend just sent me a torque chart. 1/4" grade 8 are at 10.5 ft pnds. ![]() The wheels use 20 bolts per assembly. KT
MBruns for President
dude - use quality bolts - I've broken bolts on three piece wheels that used inferior quality bolts - turn 10 having a wheel split at Sebring - not for the faint of heart
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Navin Johnson
Torque on rim half bolts is typically so low that the spec is given in in/lbs rather ft/lbs. And use the hardware recommended by the wheel maker... Or use the cheap hardware store bolts and torque to a random high number...then pray the wheels stay together during every turn..... Really are these fasteners the place to be cheap? And we use a Dow product to seal the halves, but it is pretty expensive...so just get some Home Cheapo silicone to seal the halves...
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others Last edited by TimT; 12-18-2013 at 07:33 PM.. |
JW Apostate
OK. What's better than grade 8? They're 1/4" bolts. KT
JW Apostate
what are an example of recommended fasteners? What wrong with GE silicone? KT
Driver
I had to reseal a wheel once and used GE brand silicone (obviously the stuff made for aluminum). No leaks in the intervening several years.
Jeff Alton recommended Dow Corning 832 RTV Sealant Gray. Another wheel manuf told me that if I couldn't find that, then to go with 3M Super Silicone Sealant 08664 Black. I couldn't find either locally, so I went with the GE Silicone II for aluminum and metal.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa Last edited by Noah930; 12-18-2013 at 10:08 PM.. |
JW Apostate
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
Racer
Did the wheels originally use metric or SAE fasteners? What grade fasteners were used by the manufacturer?
^^^ This is where I would start. And then use the manufacturer's recommended torque. This is not an application where you go to Ace Hardware and "wing it".
I'm doing the same thing (as soon as I get off my butt and finish) and I called HRE and got their recommendation on torque for my particular wheels.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
likes to left foot brake.
when I restored some old BBS rims got the hardware here... not sure if they have what you need, Replacement RS Assembly Bolt - Chrome |
Don't use Home Depot crap. I twisted a 5/16" bolt in half the other day with very little force.
Randy '87 911 Targa '17 Macan GTS |
JW Apostate
I don't know. These are old, unusual wheels. 1/4" bolts fit in the opening, but 5/16" doesn't. I'm not seeing a grade higher than 8 for bolts. Truthfully, I suspect any one of us could sheer off any 1/4" bolt on the market with a ratchet wrench. So, that being said, what makes a wheel bolt stronger or more special than a quality hardware store, grade 8 bolt? thanks, KT
I got my specs from Black Forest when I bought the fasteners, maybe call them.
ASTM A574 is the spec for common socket head cap screws (exceeds SAE Gr 8). Metric 12.9 fasteners exceed GR 8. Gr 8 is not really very strong in the world of high-strength fasteners.
JW Apostate
Maybe I don't understand, but if I use grade 8 bolts that properly fits the holes for the wheel assembly and torque them to a proper value, why would they fail?
There are twenty bolts per wheel, how would they just start breaking? thanks KT
