need help (quick)
OK, a Jeep shop just replaced the oil pan in my older Grand Cherokee. Now 36 hours later I get a "check gauges" warning light and the oil pressure gauge is going haywire (goes from zero to proper temp then back to zero, back and forth).
Any ideas before I go back and rip the Jeep shop a new one? thanks. |
I would check the oil.
Jimmy Foster 78 911 SC |
I would check for Porsche content, then probably post to a Jeep forum somewhere.
Bob S |
. Some newer engines have a temp/ oil level sensor in the side of the pan and a newer Jeep might have that. You have said temp and pressure so I am guessing you mean your pressure gauge is fluctuating.Your oil pressure gauge wire was probably in the way when the pan was changed.
Like a 911 the gauges are electric and electric gauges are easily affected by a loose wire at the sender.BUT first check the oil level with the dipstick to be sure they remembered to put oil in after changing the pan. (It does happen ). Then I would suspect the push on connector at the appropriate sensor is loose. If you can,t locate it easily ,then take it back to the garage that did the pan and have them fix it . It should be as easy as pulling the connector off and pinching it slightly with needle nose pliers and then reattaching it. The location of the sender varies by which engine you have so I can,t help you actually locate the sender but I think it,s the most likely cause of swinging gauges on any vehicle. If it has oil in it. If the garage didn,t disturb the wire when doing the pan then it,s likely just a coincidence that it happened now Porsche specific content isn,t an issue .
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 Last edited by johnsjmc; 01-09-2014 at 10:02 AM.. |
Don't be a snob. Is this who we are and how we act around here when another member needs help? If I had an emergency question about my BMW I would ask here too because I know I would get some good answers.
Chris '75 911s Targa |
Since a 996 isn,t a real Porsche I wasn,t overly surprized at his inability / lack of help. (I don,t know how to do green font and will seek guidance from an all natural/organic forum about how to do it.)
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 Last edited by johnsjmc; 01-09-2014 at 09:14 AM.. |
cycling has-been
any of you guys ever hear of the OFF TOPIC forums?
(open to any, and all, non-Porsche related topics)
73 911T MFI, 76 912E, 77 Turbo Carrera |
And since this is OT, I'm pretty sure you can ignore at least one of the replies you received.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
The Unsettler
Check gauges and a bouncing needle you do immediately think wiring.
Agree most likely just a bad connection. We all know what havoc bad grounds wreak on 911s. And FWIW it's been my experience over the last 11 years that the 911 owners here are generally car enthusiasts and the breadth of vehicles owned by us has created a collective of info that is hard to rival even from a dedicated (insert make) forum. First place I would come with a question about a non P Car.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Did you get the memo?
I agree with the other guys, they probably dorked something up when changing the pan. Crawl under and check the connections. Also check the sensor itself, it's possible they cracked or damaged it when removing it from the old pan and installing it in the new one.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
Virginia Rocks!
Wow. And they say its rough in the OT forum. SMH
moderators - thanks for moving this.
Bob S |
Oil pressure sending unit failures are common on Jeep/chrysler products. Don't beat the shop up too bad just yet, may not even be their fault. The senders on the l6, and v8 jeeps are not really in the area of the oil pan, and sometimes, just unplugging, and plugging one back in, or disturbing nearby wiring is enough to finish one off.
No left turn un stoned |
Parrothead member
What year Jeep and motor?
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
Parrothead member
