Is there such a thing as a metric Phillips bit?
0 seemed too small and #1 too big. Someone who I thought should know said it was metric. I did a search and I did find a reference on a RC forum but that is it.
Rick 88 Cab |
Here is some description of various screw drives:
List of screw drives - Wikipedia, the free encyclopedia
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
Honey Badger
There are Japanese bits called JIS, IIRC. They look similar to Phillips, but internal design is slightly different.
ETA: there are also posidrive bits, but they are used more in Europe. Last edited by theFONZ; 02-02-2014 at 07:54 PM.. |
The Unsettler
I stumbled upon a 3.5 mm fastener last year and found I had a 3.5 box that was in a set I've had for decades but never used, didn't even know I had it.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Almost Banned Once
Check the Wiki link... I bet it's a Pozidrive.
- Peter |
Pozidrive or the stupid Phillips head with a square in the middle. A combination drive that allow a sq drive to be use to prevent cam-out. A Phillips driver will work, bur slips often. I still think its Pozidrive.
it is not a pozidriv or even that French drive in the wiki link. I can't find any reference to anything outside the range of #000 to #4.
It is a small screw with Locktite that is difficult to remove. A new #1 bit will get it out. I think the guy just made the metric bit part up.
Rick 88 Cab |
Honey Badger
Look up JIS. A Phillips will usually fit a JIS style screw, but it's better to get the bits from some of the Japanese toolmakers.
Parrothead member
Metric Phillips? Would that be a "Philippe" bit....
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
Control Group
If it has loctite on it, can you heat it up, or would that damage the piece"
She was the kindest person I ever met |
Almost Banned Once
This has me very curious. I'm very fussy about screw heads and I always use the correct non worn screwdriver tips to remove them. Generally tips/screwdrivers by Snapon or Starrett are the best fitting. My ultimate goal is to remove and reinstall them without marking them. (One of my hobbies is repairing old film cameras and lenses)
- Peter |
Heat the head with a soldering iron.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Used to be Singpilot...
Location: Sioux Falls, SD is what the reg says on the bus.
I sold a Metric Crescent once. To a girl that was looking for one.
Bill is Dead.
Frearson?
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
Sounds like the JIS. is what I found on a fan this summer. Tried several different bits to undo them. Ended up using a BFH to smash it to pieces. BFH's work best on all screws types.
Bunch of old cars
I looked at them again compared to another Phillips along with a Google search and I bet it is a Japanese Industrial Standard (JIS) Screw. How it ended up here is another question but the thing does have its origin in the Pacific rim.
Rick 88 Cab |
The Phillips heads are different on some screws. If you look at the bit, some are more angular and some not so much. A new bit will cam out on you if use with different Phillips slots. The slot on a drywall screw and the typical sheet metal screw are slightly different. Love to see a pic because it is bugging the hell out of me not knowing what it is?
I have used these thing before with some success. How big is this screw? Sears.com
