Hi
Question Replacing VW Head Gasket
Hello Everyone,
![]() I have a question regarding using sealant on a head gasket. I'm working on a 2002 VW Golf with a 2.0L engine. I'm replacing the head gasket because I had water leaking into the exhaust which has clogged the 02 sensors, (both) and is clogging up the CAT. ![]() The Fel-Pro gasket I bought is a MLS gasket (Multi Layer Steel) and according to Fel-Pro no sealant is necessary. I was considering using a sealant only because this is a big job and I'm spending a few hundred dollars on O2 sensor and a CAT and I don't want to have to do this again. ![]() Do any of you have experience using sealant on MLS gaskets? Thanks in advance. ![]() L
"A good sense of humor is the best thing to have in your toolbox when working on these cars." Quote by Charles Freeborn, Pelican. |
drunk and stupid
When I did the top end/cooling refresh on my Series I used a MLS gasket.....no sealant and no problems.
did you get the head cut/valve job? a straight head is more important than a gasket sealer.
i used that copper spray gakset on the head of my mazda. it really depends on the gasket materiel but i dont remember what mine was.
Still Doin Time
Hi, unless I am missing something in your post you state you had 'water' (coolant?) leaking into the exhaust. The only way for this to happen is there is a breach in the cylinder head between cooling passages and exhaust seat / port.
If your head gasket has failed you'll have coolant in the combustion chamber, which then exits into the exhaust. If this happened that combustion chamber will be clean as a whistle and you'd have misfire codes......................... If you're not sure, you'll need to have the cylinder head pressure checked to rule that out.
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
What asphalt said. I send every head out, and have it pressure checked, and milled . It prevents comebacks.
Gasket goes on dry to a perfectly milled head and a really clean block surface. If you are trying to get by without milling the head, a few light passes of that spray gasket may not hurt. I don't see those cars blow head gaskets all that often. I am usually removing the head because a belt broke, and smashed all the intake valves Good luck
No left turn un stoned |
Now in 993 land ...
It is coated with a polymer or is it a straight up steel surface?
I would go on a VW board and inquire. Generally FelPro is a top company, and I would go with their recommendation. I have used MLS gaskets from them before and they were all coated with some sort of polymer. G |
The Unsettler
Check to make sure the head bolts are not TTY.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
They are, just replace them
