-   -   My next project is a... (http://forums.pelicanparts.com/off-topic-discussions/798976-my-next-project.html)
gacook 07-15-2014 03:26 PM
That blue is absolutely gorgeous on that car.
mreid 07-18-2014 07:23 PM
They started bonding the doors and hood together. Carey says they are perfectionists in gaps and it takes 2 to 3 weeks to get the door gaps just perfect. Some of that is due to the doors extending into the roof line.
http://forums.pelicanparts.com/uploa...1405736508.jpg
http://forums.pelicanparts.com/uploa...1405736866.jpg
http://forums.pelicanparts.com/uploa...1405736883.jpg
http://forums.pelicanparts.com/uploa...1405736590.jpg
http://forums.pelicanparts.com/uploa...1405736611.jpg
http://forums.pelicanparts.com/uploa...1405736629.jpg
mreid 07-25-2014 03:15 PM
Work continues. Doors are hung (check out those beefy hinges) and they're working the gaps. The hood was also fitted and hung. Once the rear half is hung and fit, it all comes apart for priming, blocking and painting. Only a few more months!
http://forums.pelicanparts.com/uploa...1406326479.jpg
http://forums.pelicanparts.com/uploa...1406326500.jpg
http://forums.pelicanparts.com/uploa...1406326518.jpg
http://forums.pelicanparts.com/uploa...1406326534.jpg
mreid 08-01-2014 04:18 PM
It's starting to look like a 904!
Check out the "lightened" hinges:
http://forums.pelicanparts.com/uploa...1406934999.jpg
And the rear installed:
http://forums.pelicanparts.com/uploa...1406935056.jpg
http://forums.pelicanparts.com/uploa...1406935079.jpg
And finally, one more Albert blue inspiration shot:
http://forums.pelicanparts.com/uploa...1406935126.jpg
Bill Douglas 08-01-2014 04:36 PM
Whoo, I'm in love with that car already. Great fabrication skills.
skipdup 08-01-2014 04:42 PM
Can't wait to see this in person!
mreid 08-03-2014 09:56 AM
There will be a coming out party!
I just love the lines on this car:
http://forums.pelicanparts.com/uploa...1407084948.jpg
Tobra 08-03-2014 01:24 PM
Are you doing anything to improve the ventilation to the cockpit? I have heard that getting hot is a problem in those. I saw a Miata with a little round vent that was apparently from an airplane on the little triangular window in front of the one that rolls up and down. You don't have a quarter window on a 904, I don't think. I guess you could make more than one style of plastic window out of lexan without that much trouble. They slide fore and aft I believe, rather than rolling down.
Embraer 08-03-2014 09:44 PM
awesome, just awesome.
scootermcrad 08-05-2014 04:43 AM
I'm enjoying the progress pics! Keep them coming!
Do you per chance know the accuracy of the body dimensions of this compared to the original? Is there changes to "cabin" area for creature oomforts or left true to the original? I've really been interested in going down and paying a visit to Beck about these cars. They really look nice.
mreid 08-09-2014 09:08 AM
Scooter, here is a link that compares an original to the Beck: Beck 904 -- The Ultimate Replica
Doc, I plan on fresh air vents from the nose dumping under the dash with a cable control to shut off the air flow. A/C is an option I didn't want.
All gaps are set and the body is ready for high build primer, prep, and paint!
http://forums.pelicanparts.com/uploa...1407600481.jpg
http://forums.pelicanparts.com/uploa...1407600497.jpg
http://forums.pelicanparts.com/uploa...1407600516.jpg
stealthn 08-09-2014 09:51 AM
So how does it get registered? As a kit car?
mreid 08-15-2014 05:56 PM
Depends on the state. In Texas, as a specially constructed vehicle.
mreid 08-22-2014 02:21 PM
Not a lot to report, but the oil cooler, rear vents, and headlight openings were cut and the fitting of all components continues. This is the "you have to build it twice" approach. Build it to ensure it all fits, then take it all apart for paint.
http://forums.pelicanparts.com/uploa...1408742426.jpg
http://forums.pelicanparts.com/uploa...1408742453.jpg
http://forums.pelicanparts.com/uploa...1408742469.jpg
http://forums.pelicanparts.com/uploa...1408742485.jpg
mreid 08-29-2014 04:06 PM
Fitting all the lights and it's starting to look like an actual car!
http://forums.pelicanparts.com/uploa...1409353448.jpg
http://forums.pelicanparts.com/uploa...1409353506.jpg
http://forums.pelicanparts.com/uploa...1409353535.jpg
The dash is also roughed and ready to be fit. There's a back up in the paint shop, but won't be long now!
http://forums.pelicanparts.com/uploa...1409353597.jpg
mreid 08-30-2014 05:45 AM
How about a little tail?
mreid 08-30-2014 05:47 AM
Oops!
http://forums.pelicanparts.com/uploa...1409402810.jpg
http://forums.pelicanparts.com/uploa...1409402828.jpg
http://forums.pelicanparts.com/uploa...1409402864.jpg
Hawkeye's-911T 08-30-2014 10:05 AM
Hey 'mr'
I finally read through your thread today - very cool indeed! Also 'stealthn' brought up an interesting point: "So how does it get registered? As a kit car?" At any rate, I now have to clean up the drool on my key board.
Cheers
JB
daepp 08-31-2014 09:12 AM
I love this build - I am inspired by your progress and determination.
Obviously time and Beck have perfected the fiberglass-to-chassis bonding issues. But I'm curious, if someone made one of aluminum, would it perform much different than the fiberglass? Especially now that we can drop in such a glorious powerplant as that 3.6?
Tobra 08-31-2014 09:19 AM
I suspect it would, as I would expect aluminum to be much stiffer. On Mr Reid's car, the strength is going to come from the frame, on the original, the body would to the strength to a greater degree, or that would be my expectation.
