Chill from the past
My son and I just got home from the PCA meeting. It's 37° and foggy / drizzly.
We were barely home and my son told me the neighbor kid (20) wanted me to come over and check his Beetle (74 Super Beetle).
My neighbor passed away last year. His sons are friends with my sons and I've long been a consultant on auto issues. They have an E30 as well as the Beetle.
We get over there and the beetle is idling rough, with the lid open. The owner asks " what is that stuff on my carb and why is it running bad?"
Carburetor Icing! I haven't seen that in over a decade!
Old 03-19-2014, 08:09 PM
wow, I've never seen that or heard of it. But then I've not spent that much time up North either.
Old 03-19-2014, 08:14 PM
This temperature (just above freezing) and near 100% humidity, plus a carb that has no heating provisions and that's what you get.
As the air accelerates through the venturi the temperature drops.
Icing on the cake - the throttle was sticking open as he drove it home.
I love these young guys working with the old cars ( they still have 2 65 Galaxie convertibles that were their dad's).
Old 03-19-2014, 08:19 PM
FUSHIGI
that situation gets serious in an aircraft.
Old 03-20-2014, 03:01 AM
I had carb icing in an old 83 Ford pickup with a 300CI inline 6. Somebody had removed all the "junk" around the carb when they rebuilt the motor.
Old 03-20-2014, 04:15 AM
recycled sixtie's Avatar
That takes me back to the 1960's when I was working on the surface of a mine in Elsa, Yukon. This ex Englishman there had a Mini Cooper S(1275cc) and said he experienced carb icing that I thought only in retrospect piston engine aircraft experienced.
I forgot about that and I have never had any car in my life experience that.
It is indeed great that you can help out others with their cars especially the young ones.
Cheers, Guy.
Old 03-20-2014, 04:54 AM
Puny Bird
Mark Henry's Avatar
If it's bad and you have to make it home take a pee on the carb.
Not joking.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 03-20-2014, 05:09 AM
in the winter we used to zip tie a piece of plexiglass over the engine lid louvers to keep the heat in. helped a lot.
206 637 4071
Old 03-20-2014, 05:15 AM
Back when I was 15 I helped my brother build a dune buggy from a VW. The engine just hung out in the air. Down in Alabama on a cool day while driving around it started running real bad. We pulled over and the carb was a block of ice.
We hooked up a new preheat manifold after that weekend.
Old 03-20-2014, 05:19 AM
Kantry Member
oldE's Avatar
The carb iced up once on me in the '73 Torino under the conditions described above.
It was like trying to run with full choke. No power, black smoke from the exhaust.
We limped into the next town and a couple of bottles of gas line de-icer and the heat from the engine cleared it.
Best
Les
Best
Les
Old 03-20-2014, 06:03 AM
Petie3rd
Mrmerlin's Avatar
my 76 FJ40 with a Holley 2 barrel conversion, it would ice up when it was cold out,
the trick was to keep it running long enough to get some heat into the engine,
usually about 10 mins then shut if off,
and let the carb warm up usually about 5 more mins
otherwise you could find the throttle stuck at way more than idle
Old 03-20-2014, 06:52 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
This is why there's carb. heat (or injection). Anyone who's flown an older C172 will know it well as part of their basic procedures. I still have it burned into my head from the first plane I ever soloed (a PA28) as part of the engine power loss troubleshooting procedure, "mixture rich, fuel pump on, carb heat on, switch tanks". Would be simple enough to rig up on a car I'd think - one cable, a butterfly valve, two metal flex hoses and a few clamps...
Black Cars Matter
Old 03-20-2014, 07:16 AM
FLYGEEZER's Avatar
Back in the day....When I was flying "round engine" aircraft, carburator icing could occure at +15C and below. Carb heat is term now that only flyers of small piston driven aircraft are familiar with.
Edgar
1984 Porsche 944 bone stock
1995 Mercedes E320 wagon
1970 Honda CB350 mint!!!
Old 03-20-2014, 07:33 AM
Old 03-21-2014, 10:36 PM
