Missing a connecting rod...
has anyone seen it?? :confused:
Apparently, I have angered the Jeep gods again... http://forums.pelicanparts.com/uploa...1397154967.jpg |
Ouch! Not good vinny!
Look at the bright side...your chassis is freshly lubed. :D (ducking.....)
Don't ya just hate it when that happens??
Duct tape!
I figured a couple tubes of JB Weld I'll be good as new.
That just helps to keep the rust off the underside. I would use an expandable rubber plug in the hole and some heavier oil
I bet the CIA, FBI, & IRS conspired to steal it! They needed it to keep hiding that missing airplane!
Next time your jeep starts telling you a knock-knock joke, I bet you will ask "who's there?" faster!
4, 6, 8? Old or new?
Will that buff out??
I had an Audi that ran fine with only 5 cylinders. I'm sure the jeep will too.
That looks like the bottom of a 4.0. I am guessing 99 or newer. Remember when the 4.0 was considered invincible? I wonder if piston cracked first. I have seen a bunch of them come apart only to find the piston skirt laying in the pan, or jammed into a counterwieght.
I think up to these years, they were great motors. |
The Aussies are listening for it pinging.
It's a '99 4.0 Around 600 miles since a rebuild. Gave me about a 4 second warning before it let go. Had been running absolutely perfect before that.
This is why I rebuilt it in the first place. http://forums.pelicanparts.com/uploa...1397164425.jpg |
I've done 3 or 4 that looked exactly like that one. Whole side of the piston missing. The earlier ones ( 99, 2000)and seem to be the habitual offenders. I think I crank kit is fairly cheap, but I find that they suck to r&r .
It is nearly impossible to find a used motor for one of these, they all blow up. |
Piston skirts and heads cracking between # 3 and 4 are the most common issues with these motors. When I did the rebuild I went with Speed Pro pistons. HUGE difference in piston design and skirt construction. I'm really pissed, because this is the first time I've had a rebuild let go on me. ( other than a race motor..) and like I said, I had absolutely no warning.
No warning, catastrophic - I'm sayin' rod bolt failure.
Vinny, remember those extra bolts you had after you rebuilt it? Yeah they go there. (all meant in fun)
| All times are GMT -8. The time now is 07:13 AM. |
