Is very busy
Why rear-mounted turbos on a front-engine car?
I've noticed some front-engine cars with an aftermarket turbo conversion feature rear-mounted turbos. What is the exact purpose of mounting the turbo in the rear of the car, far away from the engine? Wouldn't the boost pressure also gradually decrease as it has to travel a long distance to get to the engine compared to a turbo that's mounted in the engine bay, where the piping is much shorter? My theory is the engine bays of some cars have no room left for any turbos. I've seen this rear turbo setup on some Corvettes and 350Z's, but in some cases the turbo(s) are actually mounted in the engine bay, which kinda rules out my theory of a completely full engine bay.
This strange turbo setup doesn't really make sense to me, so my question is how is it in any way practical to mount the turbo(s) in the rear of a front-engine car?
Jason 1987 930 Slantnose Cabriolet, 545 hp, Guards Red- Weekend cruiser 1986 944 Turbo (951), 350+hp, Guards Red- Track car 2005 Toyota Tundra SR5 Double Cab 4x4, stock 282 hp, Silver- Daily driver Last edited by TheRedSlantnose; 07-08-2014 at 04:16 PM.. |
Easier to find a place for it in the rear...
Just don't plumb it with PVC! |
I'm with Bill
Electrical problems on a pick-up will do that to a guy- 1990C4S |
Conventional wisdom is that the closer to the motor, where the most heat is coming out the exhaust, the more efficient the turbo set up will be
BUT....I've seen the rear mounted turbos on Corvettes and a few knowledgeable people that drove ./ ridden in them were amazed how well the cars performed. The exhaust gases do cool off some as they travel down the tubes to the back, but it looks like that energy lost is no big deal when it comes to getting horsepower. I would be curious to see how a back to back comparison would be on a road course. You might think the spool up would have a fair amount of lag. then again the turbos are rather small on these installs. Wonder where the cavitation points are
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
Model Citizen
Here's some propaganda from STS. Much of what they say makes some sense, but I'll bet the main reason is that the engine bay is packed.
STSTurbo.com: Why Rear-mount Turbo
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
Unregistered
STS makes a very good system and they put the turbos back there because that is where there is room.
It is actually more complicated to put the turbos in back because they have to have an oil pump in the rear to pump the oil back to the forward sump. |
Platinum Member
Recreational Mechanic
Hell why not mount the entire engine in the rear....oh, wait....yeah.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
Unregistered
The sds system i saw used the space for the stock mufflers for the turbos. not a lot of extra room for things like a tank and cooler. It was simpler to use a small sump pump to put the oil back to the front where it is filtered and cooled. |
Owner liability probably. Owners wouldn't change a rear oil system.
I think the turbo and intercooler should all live in a foot high lump in the middle of the hood.
Dog-faced pony soldier
Only on Hondas and Mustangs though.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Slackerous Maximus
I actually don't understand how this could work. Given the absurdly long run from the turbo back to the intake manifold, isn't the lag huge?
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
Guy '87 944 (first porsche/project car) |
Banned
lag
small wheel spins up faster then a bigger one vetts with 6-7 L get lots of flow rear turbo also removes heat from confined space under the hood not the best for max efficiency but plenty for a street car with 400-500 hp btw a small turbo like volvo used gains mid range power not so much at peak for better fat tork drive-ability |
Unregistered
Here they explain why they did it that way:
STSTurbo.com: Why Rear-mount Turbo |
It is not the ideal place to mount them fundamentally. Lets say it is "25%" worse than putting them where they belong near the exhaust manifold and the throttle body.
Turbos are super fantastic and even 75% of super fantastic is pretty great (highly quantitative methods involved here). They are generally used with big engined cars that dont struggle with low rpm torque anyways. A turbo vette is fine "spooling" at 4 krpm, it can still fry its rear tires from idle to 3999 rpm anyways. After first gear you can keep it in its powerband.
84 930 18 Cayman GTS |
