rfuerst911sc's Avatar
dissimilar metals question
Yesterday I had the fun of cutting off the steering wheel on my new to me used boat I tried penetrating oil, heat and a gear puller she was frozen on there. I did get it off and now I will be installing a stainless steel steering wheel. Not sure what the hub of the SS wheel is made of but it's either cast aluminum or stainless. The steering shaft is steel. So what should I use as a lubricant between the hub and the steering shaft ? Should I use silicone grease, regular grease , lithium grease or anti-seize ? If anti-seize do I use copper or aluminum based ? The goal is to minimize corrosion and dissimilar metal galling so in the future if I have to take the wheel off it can be done without destroying it I'm a little concerned about using anti-seize only because if it " runs " due to heat/moisture it will run onto the dash panel. And we all know how anti-seize gets on everything !
Old 08-03-2014, 02:05 AM
My friends call me, Top
Skytrooper's Avatar
If yu can find Plasti-lube, that would work best with a light coating. You could also paint the splines lightly for added protection. Just don't assemble while the paint is wet.
Matt
'87 924S
Old 08-03-2014, 05:15 AM
MDH MDH is offline
Corrosion Prevention & Metal Protection by EckŪ
We used this product when I worked for
Carver Yachts. Worked very well.
1988 924S
It's still cheaper than psychotherapy...................
Old 08-03-2014, 05:52 AM
Control Group
Tobra's Avatar
Man I love this place
Old 08-03-2014, 05:58 AM
Targa, Panamera Turbo
M.D. Holloway's Avatar
ahh yes, galvanic corrosion! When two dissimilar metals of different valences are left in contact with an electrolytic solution like water or salt water the exchange of electrons ensue. The upside, electricity happens, the downside is that the metals oxidize and become brittle. A few ways to inhibit such action...
Michael D. Holloway
https://5thorderindustry.com/
Old 08-03-2014, 08:45 AM
Try Tef Gel - been using it for 15 years with aluminum on steel in salt water and the parts always come loose
Old 08-03-2014, 09:35 AM
Takin' hard left turns
Amail's Avatar
I've been designing subsea instrumentation and enclosures for 25 years, so this is right up my alley.
Tef Gel is great. I prefer Fas-Torq A/G. If washout may be an issue, use Marine Grade Never-Seize.
Old 08-04-2014, 06:36 AM
VincentVega's Avatar
I've used Lanocote with good results.
Old 08-04-2014, 06:45 AM
+1 ^ on the lanocote, good stuff
Old 08-04-2014, 09:41 AM
