biosurfer1's Avatar
Plumbers, why was my tub plumbed this way?
I am replacing the handles on my roman tub which has been a joke in complexity and length thanks to the dumbass valve companies, but that is for another discussion.
I have to replace the valves and I'm not sure if what I'm seeing is normal or was a shortcut when the house was built.
The copper pipe coming out of the wall is 1/2", it is then reduced down to long spooled 5/8" run, then goes back to 1/2" at the current valve.
My question is two fold: Is there a good reason the pipe was reduced at all? Why not just 1/2 the whole way? Pressure related?
Also, from the pipe coming out of the wall to the actual valve was ~2ft. yet the original plumber has about 5ft of the 5/8" pipe spooled up before the valve right now...any reason for that? maybe just in case the tub handles were installed some other place than where they are currently (close to the wall)
I can take a couple pics if I didn't accurately describe things...thanks!
1992 968 Polar Silver
2010 Toyota Highlander SE
2006 Lexus LS430 ML
Old 11-15-2014, 08:46 PM
spooled? That might mean its tubing, so it should be 1/2". No big deal really in terms of float pressure.
The lazy plumber's help just did not want to walk to the truck for a cutter so he left it and slammed the tub in place. His boss weren't there so what the heck. I think that's what's going on. Yeah, need pics to clarify. No big deal really. YOu just have to drain that 5' of water in the tubing is you need hot water. A little waste that's all.
Old 11-15-2014, 09:00 PM
You do not have permissi
john70t's Avatar
K.I.S.S.
The 5/8 pipe section fit at the time.
It was sourced with a piece of scrap copper tube in the back of the plumber's truck.
1/16" difference doesn't affect any flow.
Old 11-15-2014, 09:37 PM
Bland
unclebilly's Avatar
You know that 5/8" is bigger than 1/2" right?
Seriously though, a length of coiled up tube could have 2 functions.
1. If it is loose, this could act like a snubber to prevent water hammer.
2. This could have been done to facilitate assembly (solder everything up and slide it into place). This is kind of like how gas dryers, stoves,and dishwashers are plumbed in.
As mentioned,without pictures,nobody can be 100% sure.
Old 11-15-2014, 10:51 PM
Band.
I agree that maybe the slack was to be able to get behind the tub and hook everything up before sliding it into its spot.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 11-16-2014, 06:19 AM
biosurfer1's Avatar
I meant 3/8" (not 5/8")
Here is a pic of what I'm seeing. The valve basically goes directly above the spooled copper pipe.
So there is no reason to have all that extra copper? I'd rather just remove it and run some pipe straight to the new valve.
2006 Lexus LS430 ML
Old 11-16-2014, 12:53 PM
Senior Advisor
James Brown's Avatar
that is fuched up, friction loss is huge in that ⅜ tube, no flow to the shower head or will take hours to fill the tub. I would replace with ½ tubing at a minimum. And use a balanced single lever mixing valve and your done.
08 Cayenne Turbo
Old 11-16-2014, 01:43 PM
Mickey Mouse....
Old 11-16-2014, 01:46 PM
biosurfer1's Avatar
Thats what I thought...it did take forever to fill the tub.
So next question...to remove the spooled up copper, can I just take my torch to the fitting shown and should the old solder melt and I can remove it or will I have to do some cutting?
I'm planning on putting a 1/2" copper stub at the the 90 then running flexible tube with sharkbite fittings on both ends...any issues with that? The tub will cover all of this so I don't care about looks at all.
2006 Lexus LS430 ML
Old 11-16-2014, 03:04 PM
Band.
Yeah, sorry; I take back what I said. That looks pretty dumb.
Does the fixture end accept 1/2"?
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
Old 11-16-2014, 03:24 PM
Lazy asses that didn't want to take a hike to their trucks to get a cutter. Boss felt asleep on the job and didn't check on his guys. 3/8" is what the Valve inlet calls for? You aren't going go get much more flow out of your spout because most of the valves are regulated to, I think its 2.2 GPM.
Take it in and see if they have a 1/2" adapter inlet for that valve. I am not sure if that will flower any more that what's already regulated.
Old 11-16-2014, 03:50 PM
biosurfer1's Avatar
it hard to see in the picture, but those 90's at the ends of the arrows are 1/2", they just sweated in a reduced immediately that isnt showing in the pictures.
I was hoping I could just remove the reducer, 3/8" tube and old valve and start fresh with 1/2" the whole way...will that not work?
2006 Lexus LS430 ML
Old 11-16-2014, 05:20 PM
1980 911 SC
I have replaced all the copper pipe in my home with cpvc myself. Haveing said that I am not so sure I would want the shark bite conectors behind a wall where I could not get to them easily in case of a leak. Buy nature they flex a little bit with the on/off flow of the pressure. The sharks did work just fine for me as temporary fittings during the month it took me to replace all of the copper with plastic. Not sure I would want a shark behind a wall. But then I am not a plumber.
Life's a Beach
Old 11-16-2014, 05:45 PM
Detached Member
Hugh R's Avatar
Originally Posted by flyenby View Post
Mickey Mouse....
I'm sorry but I work for Mickey Mouse and we'd never do schit like that.
Hugh
Old 11-16-2014, 07:56 PM
Jolly Amaranto's Avatar
I have gone to PEX for all my pluming lately. Sure makes things simple for me.
Old 11-16-2014, 08:01 PM
Bland
unclebilly's Avatar
Remove the 1/2" elbows and go to pex adapters. These are very easy to work with.
Old 11-16-2014, 08:07 PM
Absolutely this. Why make life difficult when PEX will totally take care of it for you.
'87 924S (Sold)
Old 11-17-2014, 03:47 AM
That's what I would do.
Old 11-17-2014, 09:38 AM
Be careful with large home center stuff. Buy a product where you know they will carry replacement valves.
Old 11-17-2014, 09:41 AM
plumb4u2's Avatar
Lol that is funny
you gotta remember back in the day copper didn't cost anything so they were just being lazy and/or just getting rid of some left over material
there was absolutely no reason for leaving the loops like that
and yes you can just unsweat the 1/2" 90s and then solder on new fittings...you will need to clean the solder off first though with sandpaper so new fittings will fit
Justin
84 Carrera Targa
98 F-150 4x4
Old 11-17-2014, 03:02 PM
