Arizona_928's Avatar
LSD in a fwd?!
Does anyone have one that will share their experience with? I'm used to the 928 with LSD, but no experience with FWD besides a bunch of understeer.
Looking into one for the mk6 since I'll be out of power train warranty in couple months. Saw that Peloquin, and wavetech offer them.
Anyone have experience with either brand?
dolor et pavor
Copyright
Old 11-16-2014, 08:52 PM
White and Nerdy
Tervuren's Avatar
Unless you're on ice/snow or warm weather tires in freezing cold, I think an open diff would be better?
That, or you're really putting down a frick ton of HP, which most FWD's aren't.
A LSD will increase your understeer in most situations with a FWD. I'd prefer without unless it were a straight line race, or I was dealing with surfaces with extremely uneven grip.
Shadilay.
Old 11-16-2014, 09:38 PM
mph911
Im not familiar with which brand to use, however an LSD in FWD car is probably the best performance improvement you could do. An LSD REDUCES understeer and helps get power down. Its common to reduce lap times by up to 3 seconds in a well set up FWD.
Matt Hart - Instagram @the_escape_road
Old 11-16-2014, 10:19 PM
Did you get the memo?
onewhippedpuppy's Avatar
This. Many performance FWD cars come stock with either an LSD or virtual LSD that uses the brakes to mimic the mechanical diff.
Old 11-17-2014, 02:16 AM
durn for'ner
livi's Avatar
I wouldn´t recommend LSD while driving any vehicle.
Markus
Resident Fluffer
Carrera '85
Old 11-17-2014, 02:54 AM
Eva
911SauCy's Avatar
Had an LSD in a race built tranny in my 'ole daily driven '98 Regal GS
Worked like a charm with Hoosiers at the track or Blizzaks in the snow.
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 11-17-2014, 04:35 AM
It will be a great improvement. Its only limited slip, its not all locked up. No reason it should induce under steer.
Old 11-17-2014, 05:29 AM
It will keep the inside front tire from converting to smoke, allowing better traction up front.
Brent
Old 11-17-2014, 07:38 AM
Geary's Avatar
The term "LSD" has been bastardized somewhat in recent years. Both of those diffs mentioned are actually TBDs, which perform well in FWD (whereas a true LSD would induce understeer in FWD). Of the two, I would recommend the Peloquin.
Old 11-17-2014, 09:41 AM
Straight shooter
Lapkritis's Avatar
Gary at Peloquin does great work and stands behind his product. I've had one of his differentials in my VR6 Turbo for a decade. I wouldn't consider any other brand for VW differentials.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 11-17-2014, 09:48 AM
Straight shooter
Lapkritis's Avatar
PS - I had one of the ARP ring gear bolts shear on my way up to Fountain Hills on Shea while tuning water-meth for the first time. Gary serviced the differential for the cost of shipping and had it back to me so I was only without for a couple weeks.
Old 11-17-2014, 09:52 AM
this is correct-
it may not the the "best" improvement- but its a damn good one.
Old 11-17-2014, 10:27 AM
Team California
speeder's Avatar
Others have already answered this but I think it bears mention that LSD refers to limited slip differential, not zero slip differential. All differentials allow differences, or differentials between the amount of torque and the turning speed of the 2 wheels on opposite ends of the axle. An open diff is basically a 100% slip differential, ie. It allows 100% slippage between the two wheels. One side gets 100% of the torque, the other side gets zero.
A stock Porsche 911 LSD used to be 40%, (if not mistaken), which offered no disadvantage in road driving under any condition, IMO. A 0% LSD diff would be a locked axle. The Evo I recently owned briefly had a Quaife LSD in the front axle that greatly reduced the *one wheel spinning* problem while exiting corners under power, particularly when the power was increased from stock.
An intelligent limiting diff in a FWD car would be one of the best improvements you could make, I would think.
Denis
Trump uses an autopen and votes by mail, in case anyone wonders.
Old 11-17-2014, 10:44 AM
Geary's Avatar
To remain consistent with Porsche terminology, fully locked is 100%. 0% is an open diff.
Old 11-17-2014, 11:42 AM
Quaife makes LSD's for many applications in FWD and have a good reputation. Now my stage rally Dodge Neon has welded front diff. Good on gravel, not so much on tarmac. I lost my powersteering on-stage once. Made for very tough steering back on the tarmac transit.
Old 11-17-2014, 11:51 AM
I think the SRT-4 came with a Quaife from the factory after the first year.
I think most racing terms 100% is locked.
Brent
Old 11-17-2014, 12:37 PM
Team California
speeder's Avatar
Okay, 100%=locked. 0% slip.
Denis
Old 11-17-2014, 12:45 PM
Just thinking out loud
mattdavis11's Avatar
My FWD has semi floating differentials, but you can lock the transfer case to equally distribute the power to the front and rear.
However, when you remove the front drive shaft, locking the transfer case is the only way it can get down the road decently. Removing the front drive shaft significantly changes the way the vehicle handles. Never tried to drive it with the rear drive shaft out. Hope this helps.
91 FJ80
84 Ram Charger (now gone)
Old 11-17-2014, 02:49 PM
Double Trouble
targa911S's Avatar
LSD changed the way I look at life..
I used to be addicted to the hokey pokey..........but I turned myself around..
75 914 1.8
2010 Cayenne base
Old 11-17-2014, 04:09 PM
Exactly... Cars like the Focus ST would be undrivable without.. Same for the modern GTIs I'd imagine.... 200+hp in a FWD makes them kinda darty....
Old 11-17-2014, 04:24 PM
