Bill is Dead.
AR spoon builders - any help?
I would like an A1 style barreled upper assy, complete less foregrip handguards and ready to install on my lower.
Kind of like the upper on this DPMS rifle. ![]() DPMS sells the above, complete A1-ish rifle, but I called and they will not sell the barreled upper only. A1 LITE 20 Odly enough, you can buy the stripped DPMS upper receiver from Midway for $132: DPMS Upper Receiver Stripped AR-15 A1 Matte And a few companies still sell the lightweight 20" barrels - such as this one from DelTon for $154. Del-Ton, Inc. AR-15 20" 1x9 Light Weight Barrel I know the build will also need the upper parts kit, the front sight and gas tube, sling ring, flash hider, etc. Foregrips not necessary, as I already have a set here. So my questions are: Does anyone know where to buy a complete A1 upper assy? If not, would anyone here be willing to build an upper assy for me? (I do not own the tools, nor do I have the experience to do this myself.) edit: Fulton Armory has a complete A1 "slickside" - but it is $800. I think we can do better building one with the parts I mentioned above! Heck, that COMPLETE rifle from DPMS is only $819 msrp! FAR-15 Legacy Rifle Upper edit 2: I guess I could just buy the DPMS rifle and swap the grips. Then either sell my lower, or use it for a different build. I'd hate to have too many AR-15 rifles laying around the house though.
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. Last edited by cashflyer; 12-02-2014 at 08:54 AM.. |
B58/732
You can pick up the armorer's wrench and action block on Amazon, if all else fails. Getting the roll pin started in the gas block is a bit a of PITA, but if you drill a hole in the end of a brass punch it goes easier. There are TONS of online videos showing how to do this--don't be askeered to try it yourself. ![]()
ΜΟΛΩΝ ΛΑΒΕ I don't always talk to vegetarians--but when I do, it's with a mouthful of bacon. |
Go-Kart Mozart
Have you tried Palmetto State Armory? They are in your backyard. Might also try CMMG. Also there is AR15 Sales. He sales Rock River and they make an A2 and National Match upper if that works. I bought a RR upper from AR15sales years ago and it was a no muss, no fuss transaction and the best price I could find. That was, however, pre-2008. -J
86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken |
Guest
Posts: n/a
I've built a couple of m16 A1 Viet Nam era parts kits. The upper is really easy to put together. Blue is right about the tools and you'll spend as much shipping as you will for the tools. The original A1 FSB uses taper pins to mount which needs to be done by a smith. Get a drilled barrell and FSB for roll pins and you're golden. Plenty of vids how to build it.
![]() Last edited by Mark Wilson; 12-02-2014 at 04:33 PM.. |
drunk and stupid
I'd be glad to throw an upper together for you or ship you my tools to use. I don't really have the free time to assemble one until after Christmas though.
Can't help with your question but has anyone found a good product to touch up black barrel after gas block has been removed and replaced with a smaller one?
Randy '87 911 Targa '17 Macan GTS |
B58/732
Sharpie.
First, who built your lower assembly? It is usually a good idea to get the same brand for the upper. However, most all brands will fit each other but some don't. Different take-down pin diameters for instance. The tighter the fit between upper and lower, the better.
It is really easy to put an AR together. Installing the front sight base being the hardest to do. You can get un-drilled front sight bases and drill and tap for two setscrews up from the bottom to hold in place. I have done this on my competition AR. Or if you get a front sight base that is already drilled for taper pins but the barrel is not, you can tap the holes for set screws (4) and secure the sight base that way too. Sighting in the front sight for zero windage would be the only issue. For tools, books and parts, Brownell's is your friend. http://www.brownells.com/ BTW, you can never have enough AR. Just sayin' |
Here ya go:
M16 A1 USGI Retro upper AR-15 M16A1 AR15 : AR15 Parts at GunBroker.com It has the teardrop forward assist, no shell deflector but the wrong flash hider. The handguard and barrel profile look correct. No mention of barrel twist. Last edited by abisel; 12-02-2014 at 02:17 PM.. |
Bill is Dead.
They are modern, current production, mil-spec. I like the link you posted. I can't remember the pin diameters on the early upper off the top of my head... will have to look them up again.
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
canna change law physics
The M15 from Armalite used to be a single casting. They now use a universal upper with a rail and add a mounted carry handle.
From Brownells http://www.brownells.com/rifle-parts/receiver-parts/receivers/upper-receivers/stripped-a2-upper-receiver-sku231000152-17601-41420.aspx?cm_mmc=cse-_-Itwine-_-pricegrabber-_-Ar-15%20Stripped%20Upper%20Receiver&gdftrk=gdfV21820_a_7c187_a_7c828_a_7c231000152_d_2 31000152_d_11224 Cheaper than Dirt DPMS AR-15 Complete Upper Receiver .223/5.56 NATO 16" 1:7" Twist M4 Profile Barrel Flat Top W/Carry Handle Carbine Length Standard Handguards A2 Front Sight W/BCG and Charging handle Black BAAP416CH
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Gallatin, Tennessee
I have bought several from these guys. Not sue if they have exactly what you need, but look around.
AR-15 Upper Receivers - Complete Uppers - Rifle Uppers - 5.56 / 223 - Surplus Ammo Dave |
Bud's gun shop has some uppers with carry handles. They are 16" barrels.
Hilbilly Deluxe
If you want someone who know what they are doing to build it to your exact specs, order all the parts you want and send them to this guy to put together: Sierra Ordnance Company |
B58/732
Just torque the nut down to min spec (30 ft/lbs. I think) and then continue to tighten until the gas tube can be properly aligned. Don't torque it past 80 ft/lbs. Seriously, there's tons of video, documentation, etc. out there. The hardest part is ordering all the parts. If I may offer an opinion at this point - I'd avoid Bud's and Cheaper Than Dirt. Both companies are known to have serious customer service and ethical problems.
drunk and stupid
Head spacing is critical, but almost never an issue for the M16/AR pattern. Make sure you buy a quality bolt and barrel and forget about it.
B58/732
There must be an echo in here!
Hilbilly Deluxe
What you really need, is a ‘I’m your huckleberry’ lower.
drunk and stupid
Thread Tools | |
Rate This Thread | |
