Burn the fire.
Brando's Avatar
Turbo Question...
On turbos, why does this intake side have the extra holes drilled? Wouldn't it make sense to just have a larger opening?
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 01-08-2015, 01:13 PM
beancounter
jwasbury's Avatar
I believe that is an "anti-surge/ported compressor housing" - supposed to combat compressor stall between shifts
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 01-08-2015, 02:09 PM
Unregistered
sammyg2's Avatar
I have never seen that before and I have played with lots O'turbos.
Old 01-08-2015, 02:20 PM
The Unsettler
stomachmonkey's Avatar
Is it a variable configuration variant?
They have a second set of moveable vanes that open and close to help spool up but them limit boost at the higher end or something like that.
Old 01-08-2015, 02:36 PM
resident samsquamch
sand_man's Avatar
Originally Posted by jwasbury View Post
I believe that is an "anti-surge/ported compressor housing"...
That's what I thought, too.
-jeff
Old 01-08-2015, 03:00 PM
speed holes
Old 01-08-2015, 04:47 PM
MBAtarga's Avatar
Pre-drilled holes to mount the muffler bearings....
Mark
'83 SC Targa - since 5/5/2001
Old 01-08-2015, 05:02 PM
motion's Avatar
I believe the power band threads thru those holes.
'95 993 C4 Cabriolet
Bunch of motorcycles
Old 01-08-2015, 05:15 PM
Almost Banned Once
sc_rufctr's Avatar
You'd probably find that this is a way of limiting boost. That is the turbo is matched to the engine performance required or desired not max HP.
Looking at the pic I would guess about half of the exhaust gas would go though the holes limiting the power gained.
Maybe it's been designed to use on cars with higher compression ratios? (That are not easy to lower... Newer crap disposable cars)
- Peter
Old 01-08-2015, 05:31 PM
Unregistered
sammyg2's Avatar
Serial, i expect they nailed it already. ^^^
its prolly a variable vane geometry compressor and when them vanes snap shut those holes allow the boost to bleed backwards to prevent surge shockwaves from breaking tips or denting bearings.
Or sumthing along them lines.
Old 01-08-2015, 05:36 PM
Bill is Dead.
cashflyer's Avatar
Google "anti surge compressor housing" or something along those lines, 'cuz that's what it is.
A Ported Shroud compressor (see Fig. 2) is a feature that is incorporated into the compressor housing. It functions to move the surge line further to the left (see Fig. 3) by allowing some airflow to exit the wheel through the port to keep surge from occurring. This provides additional useable range and allows a larger compressor to be used for higher flow requirements without risking running the compressor into a dangerous surge condition. The presence of the ported shroud usually has a minor negative impact on compressor efficiency.
http://www.turbobygarrett.com/turbobygarrett/surge_line
Old 01-08-2015, 06:30 PM
Max Sluiter
Flieger's Avatar
It's actually pretty common from what I see. It it an anti-surge ported shroud. When the turbo spools quick and is trying to flow more air than the engine can handle (or when you lift abruptly and the blowoff valve can't flow enough) it can pile up and burp back out the compressor, causing it to stop spinning and being rather rough on the bearings. To combat this they drill the holes. When the turbo is near the surge region the pressures are such that the extra flow basically recirculates around the compressor wheel, from the volute to the intake and round and round. This lets the compressor keep spinning smoothly. When the engine sucks more air the ports suck air in.
I realize this is a forum link, but the guy copied and pasted an SAE article basically. Some good pictures there: http://www.turbobuick.com/forums/threads/turbo-compressor-maps-effect-of-ported-shrouds-and-the-tornado.381448/
Burn the fire.
Brando's Avatar
Thanks for the article Flieger. Definitely some good information.
Old 01-09-2015, 10:31 AM
Straight shooter
Lapkritis's Avatar
Anti-surge.
I have the antisurge option on the Garrett T04Z mated to my VR6 Turbo:
The GT series and others have cast slots instead of drilled holes to accomplish the same function.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 01-10-2015, 04:02 PM
Dept store Quartermaster
lendaddy's Avatar
"You put your weed in there"
Cornpoppin' Pony Soldier
Old 01-10-2015, 04:16 PM
