Audi creating diesel from CO2 and H2O?
Interesting read....though it will be more interesting to see if it comes to fruition.
Audi just created diesel fuel from air and water They for sure need to figure out how to make more than 42 gallons per day to compete with regular gas though!
1992 968 Polar Silver 2010 Toyota Highlander SE 2006 Lexus LS430 ML |
Straight shooter
This is trending from Audi USA.
Audi have successfully made diesel fuel from carbon dioxide and water - ScienceAlert Exciting times...
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
I think its just the Fisher-Tropesch process, like 1925.
Short of having an excess of geothermal or thorium nuke heat, I'm not sure how awesome this is...Its very energy intensive electrochemistry.
1967 912 with centerlocks… 10 years and still in pieces! |
Hell Belcho
Still cant design a cooling system or window regulator that works...
Saved by the buoyancy of citrus. |
Control Group
Interesting
I wonder how much electricity it takes. Blue crude, I like that, has a nice ring to it.
She was the kindest person I ever met |
You do not have permissi
There should be a diesel production facility built next to every water treatment plant.
(The golden throne is a gold mine as human waste is full of lipids.) Biodiesel from sewage sludge within pennies a gallon of being competitive -- ScienceDaily New Method of Turning Sewage Sludge into Biodiesel is Low-Cost, High-Yield : TreeHugger A recycling facility for compostables and metals should be built next to every garbage dump as well. Diesel can be made from bio-mass. Gut Microbe Makes Diesel Biofuel - Scientific American Bacteria Make Diesel from Biomass | MIT Technology Review A plasma incinerator can produce electricity from the rest:High-Powered Plasma Turns Garbage Into Gas | WIRED Diesel is apparently eco-friendly. Every microbe loves to eat it. 8 Signs of Diesel Fuel Contamination by Microbes, Fungus and Bacteria Henry Ford and Rudolph Diesel were big into farming and personal self-sufficiency. Ford was undermined by bankers. Diesel disappeared off a ship. Last edited by john70t; 04-28-2015 at 08:47 AM.. |
canna change law physics
+1
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Not sure about that, BUT Henry Ford did create the BBQ Briquette industry and modern car/tent camping.
The amount of energy used to create the fuel will be anywhere from more to much, much more than will be received burning the fuel. Would be more efficient to use the energy used to create the fuel to do what you wanted the diesel to do.
Scott 1978 911SC Petrol Blue |
Straight shooter
It's hard to use tidal/geothermal/wind energy for locomotion. It has to be stored in a retrievable format... either a battery or converted to a solid fuel. I think of this blue crude as a biochemical battery of sorts even if it isn't necessarily an electrical charge measured like a lithium battery. The storage format is such that existing technologies can use it... makes perfect sense and doesn't require new consumption hardware like buying an entirely new vehicle to use the stored energy.
