Writer/Teacher
Here is the vent with the grilles removed but the restrictor plate still attached (note: this is not my car but a picture I found on the internet). As you can see, it covers the entire vent opening; I'm not sure how ANY air gets through: ![]() And this is the same vent with the restrictor plate removed. That oval opening is the bottom of the snorkel, which I see no reason for removing. ![]() I would attach the mesh even if getting the Spyder vents. The Spyder vents have very large hexagonal openings within its "mesh" (I actually think it's all just plastic, alas), and I could see debris getting through. Let me know if you have any further questions about the procedure, but once you get in there, I think you'll see it's pretty straightforward and self-explanatory.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
Did you get the memo?
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
Lots of great info here!
I need to remove that intake plate. My biggest complaint, after all of the weight and power steering, is the shifting. The shifter balks and is just garbage. I need to upgrade. |
Writer/Teacher
Of course, my previous P-cars were 944s, which aren't exactly known for razor-sharp shifts...
Compared to a well set up Wevo shifter in a 911, the cable shifter in the Cayman is really vague, and engages with a limp bouncy click, not the rifle bolt feel that you get with a Wevo.
Maybe that's the thing. The shifter in my Boxster isn't near as positive as my last miata was. The factory shifter in the Mazdaspeed miata 6 speed isn't great, but there's a short shift kit for them that isn't just a shorter rod, but actually changes the fulcrum point of the shifter while retaining the stock rod height. The shift really does feel like a rifle bolt, but in that trans, the shifter actually bolts into the top of the transmission tailshaft. I've always assumed that when working with cables that are far removed from the trans, it will only shift so good, and my boxster is pretty darn good to me.
In addition to the shifter, fresh OEM fluid can smooth out shifts quite a bit as well.
I should try fluid then. But I think the solution will be a new shifter design.
My '11 Cayman S has around 33K miles on it. It's really noticible when jumping right out of the 911 and into the Cayman. The first reaction is that the controls on the Cayman are really poor. Seating position, steering is heavy, shift and throttle are like you're in an Audi or BMW sled compared (this is the key) to an air-cooled 911. |
Back to the original topic. I can't add anything that hasn't been said in defense of the boxster. I think Porsche got it right with the 986/987. Is the IMS bearing an issue. Maybe? I replaced mine at 50k with an LN. Dual Bearing replaced was in perfect shape. I unfortunately drank the cool aid.
![]() As far as worrying what others think, that is just crazy and juvenile. So some 911 guys don't like Boxster. Really? Well some Corvette guys don't like 911's. Think they are glorified volkswagons. Have they ever drive one? Probably not. Sound familiar. ![]() David |
Guy '87 944 (first porsche/project car) |
...but it's not my old stock '88 targa. In many ways, the Boxster is better, faster, more powerful, probably handles better, is more luxurious with better AC and a better sound system and the missus likes it better. Still, the old 911 had that something extra special that I miss. I hear folks complain about the HVAC controls in the old 911s (I thought they were great). I also remember people talking about a stiff clutch pedal, heavy non-power steering, vague long-throw shifter (especially 915). The HVAC (climate control) in my boxster is pretty simple (though not as simple as you might expect), the clutch is not heavy, the steering is good (but certainly not like my old 911 also not as heavy), the shifter is much, much better than my old G50 911 (and I didn't think it was bad, never missed a gear) Quote:
What's not to love?
![]() ![]() ![]() ![]() ![]() And I've posted this before, but hey, I like my car. ![]()
^ Steve,
All good points there. The Cayman (same as Boxter) is superior in weight distribution and power. But it lacks the feedback for me. It's like having sex with a condom haha. I love the heavy clutch of the 915 because I can FEEL the exact bite point. When I replaced the clutch and pressure plate at 400K miles, they were in such good condition, I put the clutch plate on my friend's SC and he's still using it. What I really love about the Cayman is the 320 HP that Porsche claims, direct fuel injection, and limited slip. I think I should listen to Jeff Altman and maybe get a turbo 997 though. The Cayman AC is worlds better than my 911, no doubt. But the Cayman/ Boxter is no replacement. I guess I like to do it au naturale, haha! |
I'm actually not a fan of convertibles, typically; however, I think the Boxster is one car that looks much better with the top down.
my Cayman
The funny thing about me not really being a convertible guy is that my last 4 cars were an '88 targa, a '97 miata, an '04 turbo miata, and an 08 Boxster S RS60. I looked for an at a few Caymans (Caymen? ) when I bought this Boxster (which came with the optional hardtop), but the best Coxster that I found was the one that I bought. I didn't really have any choice with the Miatas (although the first one came with the optional hard top that I ended up putting on the miata that the wife got). I do put the top down, but probably not more than 20-30 times a year (probably more like 15). Mostly only when I'm by myself, and mostly only in the dusk to dawn period, and only when the weather is nice and cool.
Great analogy by the way, vis a vis riding bareback vs not.
Very nice. THere are times that I think I might like a small tail, like I think yours has.
Writer/Teacher
Going back to the comments a few posts ago (Corvettes vs. air-cooled 911s vs. Cayman/Boxster), it's always useful to remember that when 911 (901) was released, many 356 owners hated it, saying "it's not a real Porsche," that it's too bloated and heavy and with too much of a focus on luxury. Sounds familiar. Same thing happened with the impact-bumper cars; and then a similar situation with the 928. And the 924. And the 914. And ESPECIALLY with the 996.
I've talked to a few Cayman S or R owners who have done the usual power-gain mods, tightened up the suspension, taken out some excess weight, and they rave about how the end result feels more like a classic 911 than the current 911 does. Sure, steering feel isn't quite there, but the car is eminently tossable. Is that much different than someone who takes a luxurious 964 and backdates/lightens it and ends up with a car that's much more like a longhood?
