Team California
Need help ID'ing speed boat:
This is a spill-over from my 4th of July thread but does anyone know what model and approx. year this Chris Craft ski boat is? Or a web site that could help? I tried a bunch of different search terms and learned about a bunch of other CC boats but not this one. TIA as always!
Denis |
RETIRED
Looks like early 80s to me. A CC dealer that isn't brain dead should be able to help.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
závodník 'X'
^ Agree with the 80's. Flat paneled windscreen sort of dates it. Had a Formula with similar lines.
note: Thru transom exhaust. Open? Many populated lakes now have noise restrictions. Mufflers required / Db rated and no grandfathered clause. DNR is out with sound measuring and readily hand out hefty fines.
“When these fine people came to me with an offer to make four movies for them, I immediately said ‘yes’ for one reason and one reason only… Netflix rhymes with ‘wet chicks,'” Sandler said in a prepared statement. “Let the streaming begin!” - Adam Sandler |
Parrothead member
Looks like a mid '80s CC Scorpion
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
Team California
![]() Quote:
Thanks, Vinny. Now I have another search term!
Denis |
Evolved
QUOTE: "Looks like a mid '80s CC Scorpion"
________________________ Agree. I also agree that unless you only want to hold conversations when the boat is stopped with the engine shut off - AVOID through-the-hull (above water) exhaust applications. Otherwise, at most any running speed you will be screaming to the person in the next seat ..and they still won't hear you.
Don't fear the reaper. |
Team California
BINGO!
![]() 1980s CC 230 Scorpion, (23 ft.). I knew I could count on you guys, (or at least one of you), this board is better than calling a dealer or just about anyone. I'm starting to think there is no question that cannot be answered here, at least about important things like boats/planes/trucks/etc. ![]() Thanks again, Vinny!
Denis |
Team California
Denis |
RETIRED
Easy upgrade to underwater exhaust. That was an option on high end rides starting around 87. You had a switch that allowed WAAAAHHHHHH, or silent burble with water quiet.
Same Federal reg that killed the air cooled Porsche IIRC.
Evolved
QUOTE: "I'll bet it gets up and scats, though!"
____________________ Very possibly true. It all depends on the engine (size) and prop (pitch). Truly, if you are considering buying THIS boat, consider this additional problem with those exhaust pipes: The boarding ladder(s) is/are right next to those HOT exhausts! Problem enough for adults that can remember to avoid them. A REAL problem when having young children aboard. An 'accidental burn' concern - of which you need to be aware. And as you can see they make the rear 'sundeck' area all but unusable.
Team California
Denis |
Why the obsession with this particular boat? I'd think there are much better more modern boats for the money....
Banned
boat's state registration numbers should be linked to the year of issue
the last two letters will give a date GN they start with AA and go AB AC ect that does assume the boat is still in the state first registered in then see who owned the boat Corp at that time as some owners/builders are much better then others even in a NAME Corp like CC there is some real junk boats with brand names on them |
FUSHIGI
Made the mistake of looking at the price of a new Master Craft Prostar and almost passed out.
Cults require delusions. |
Are you thinking of it, or something like it, as a Speeder boat?
It would be a PITA to own in the Los Angeles city area. Parking it, taking it places... No more drunken blonde girls at parties. Your weekends would be taken up by fixing/modifying the boat. |
Isn't this what people say to air cooled owners?
Team California
Exactly. My life would be so much simpler if I could just get over my obsession with cool stuff and only buy new products.
Denis |
Team California
You are generally correct about storage space in Los Angeles but I have access to some not too far away. A boat in L.A. needs to be kept in the water at a Marina or a beach house. It would be a lot of fun to blast around the coast, Malibu and Ventura, etc.
Denis |
Dennis, what are you fighting on your trailer?
The air forums is a good source for info. And sources for parts for the older models. Like most Porsche dealers , the airstream dealers are more into servicing the newer stuff. Airforums is the Pelican of the airstream world. Lots of restorers, and DIY folks there that may be some help in your projects. Cheers Richard |
I've owned that boat, same color ... make sure it or any boat you buy doesn't have blisters on the bottom http://www.yachtsurvey.com/BuyingBlisterBoat.htm
76' 911s Signature Edition Last edited by enzo1; 07-08-2015 at 01:54 PM.. |
