Windows 10 Recovery with 8.1 DVD......
The past several days I had been experimenting with making mods to my Windows 10 upgrade and one was the lock/login screen which I hated the images. So I used a utility to change the images to some of our black powder matches and initially there were no issues. Yesterday afternoon the login screen decided not to load but would just flash and go back to the lock screen. Hummmmm, I tried starting in safe mode but the 8.1 and 10 versions are hard if not impossible to catch with either F8 or Shift+F8 so I decided to try my 8.1 DVD to see if the upgrade would roll back or ?????
After booting with the DVD it said "analyzing Windows 10 problems" which really surprised me and the it asked if I wanted to shutdown or troubleshoot so I started looking at troubleshoot options and what did I see.....a choice to roll back to a date three days ago so I selected that and it worked. The PC rebooted and the lock screen/login both are fine! I had to go through and reset the colors, backgrounds and security settings I had made but all is well now. I have NO IDEA how that worked but it seems Microsoft may have done something okay here. I am doing a recovery point each night at 1:00AM just in case so in case my adventures cause issues in the future. Hope this helps anyone out there using version 10? |
I'm mulling it over. Windows 8 is such a POS and 10 could be worse. I just went thru an event with non-loading pictures which had worked OK earlier.....2 days of pissing me off ceased when it started working again....for no apparent reason. It could easily go to hell again for the same reason.
I would be happy to go back to Vista were it a simple matter. I'll hold back on 10 for a bit.
JPIII Early Boxster |
If you are trying to do the update/upgrade and get an error, do a search on that weird alpha-numeric number that shows up and in most cases it will require you to delete directories and files in C:\Windows\SoftwareDistribution\Download\*.*. I made a RAR file of the items in that area as they are the files for all updates done to the computer. Once I did that the whole process completed in 1 1/2 hours or so.
canna change law physics
If someone can fix the issues with Office 365 and Windows 10 and Network drives, I'll be happy.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Well, at least they're admitting it is real
