Replacing a roof tile
Had a roof tile decide it no longer wanted to be attached today. Fell off and dinged my garage AC on the way down. How do I need to fix this? Never worked on tile roof before.
Deck screws?
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
They're held on with wire. It goes through the hole in the tile. The wire is wrapped around a galvanized roofing nail that's sealed with tar. It will be up under the flashing.
Those are edge tiles and they're held on slightly differently. Look at the remaining tile and you'll see the nail head through the side of the tile, nailed into the side of the rafter. You'll also notice the hole in the tile further toward the front. Those are the areas where the tiles are secured. if the fallen tile doesn't have a hole, it's probably because it was cut too short in order to fit the distance between the overlap and the flashing. It looks like the roofer may have secured it with the glob of mastic you see in the top of the overlapped tile. If the piece didn't break, you can drill a small hole in the side an nail it up. If it is broken, cut a new tile to the proper length, drill a hole, and nail it up.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 09-16-2015 at 08:54 PM.. |
It broke in half when it fell. Here is the outside edge.
That tile was cut and "glued". Shoddy job.
what Ossiblue said. See the glob of cement on top of the fallen tile? That was under the flashing. Cut tile with a small grinder and a diamond blade. Shove it back up there and install with a dab of glue (put a little more then that, will ya Sid). Not sure if drilling new holes that close to the edge without cracking the tile is possible. I have done it with 50% success. That would be the best way to ensure that the mechanical fastener will make it stay put for good even if the mastic fails. Most roofer just mastic along with cement and call it the day. They stay put pretty well until the big earthquake.
![]() You will be fine.Whenyou get up there, seal up that crack or opening with something to keep bees or other insect from entering the home. |
Umm... Sadly as with most houses built in the last 20 years here it's pretty much par for the course for the neighborhood. The trim work in our house is so shoddy I've considered ripping it all out... Looks like they rough cut it with a hatchet, then back caulked and painted it to attempt to hide the crappy work.
UnRegistered User
They call that carpenter in a tube!
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Sid, call Cat, ,she ran a roofing business for 30 years...
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
I think its ok without it, the flashing, if installed correctly, should keep the moisture out, but the cement kinda holds the tile in place and it helps a little if moisture does come through
How old's the roof? Tile should be under at least a 15-year warranty.
Guy '87 944 (first porsche/project car) |
House was built in '01. Roof is original. Good luck finding the manufacturer though...
Yes stucco has some cracks. Whole house is due for paint in the near future. |
take it to a roofing supplier and ask for a matching tile. Run you a few bucks
That's a huge problem with the stucco houses that have gone up this century; the builders don't take the time to cure it properly (takes a while) because they're trying to slap up as many housing developments as they can. Quality of work is almost non-existent, and the stucco typically starts cracking within 5 years. Like you mentioned, don't get me started on the finishing work INSIDE the house...
Min. building code requirement is the problem. How can we compare mass produced houses to houses that are build individually especially custom homes.
I understand the reason. Doesn't help that buyers want it NOW and don't understand that it takes time to build a house....
Student of the obvious
Plenty of roof tiles being trashed in my part of town.... along with windows, doors, garage doors, lumber. Demolition company is salvaging NONE of it despite requests from charities that work on houses.
Lee |
