Bill is Dead.
cashflyer's Avatar
I can't help myself....
Give 'em the clamps, Clamps!
Old 09-30-2015, 12:09 PM
Platinum Member
dad911's Avatar
Many of the Electrical threads I read about here are determining excess battery draw, or 'is it my battery or alternator' or "why is my wire hot/smoking"
That's why I highly recommend a clamp-on DC (many mutimeters are AC only) meter. Just clamp it around the wire, and measure current. Many meters & fuses smoked with people trying to measure current.
For temps a decent IR Temp gun ($20ish on amazon) is far more useful than a multimeter with a probe.
Also, As I posted earlier, the 12v test light is often more useful than a meter. It will determine not only if there is voltage present, also if it is at a reasonable enough current to light the bulb. For example, a circuit with alot of resistance(corrosion) may still measure 12v on a high impedance meter, but drop to zero under load.
Old 09-30-2015, 02:21 PM
Recreational Mechanic
Nickshu's Avatar
Ok guys after obsessing over this for awhile I bought Klein Tools MM2000 TrueRMS meter. For the price point $120 and features it seemed to be the best choice for me. This meter is comparable to the Fluke 117 but considerably less costly and has more features. A clamp meter would be nice if I was doing mostly AC but it appears clamps are tough to use in tight automotive spaces. Thanks to all who responded with suggestions.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 10-04-2015, 10:44 AM
sugarwood's Avatar
So, you're saying that if a wire is heavily corroded and has a lot of resistance, the meter may still read 12V but the wire will not be able to carry the current and power the accessory?
1986 Bosch Icon Wipers coupe.
Old 10-04-2015, 04:27 PM
Platinum Member
dad911's Avatar
Yup. As a check put a 1k ohm resister in series with the positive voltmeter lead on your 12v battery and you will still read 12v.
Old 10-04-2015, 05:10 PM
