Around here, we need to call the electric co. so they can send out a spotter for the panel. They dictate exactly where the new panel needs to go. Find out if you need to do that. Its the first step. That can take a week for them to come out. Its a free service. without the spotter's paper work, our inspector wouldn't pass us.
Old 10-20-2015, 09:17 AM
JavaBrewer's Avatar
I had my 100 amp Zinsco panel replaced last year. I used a two brother electrical crew that I found a couple years back that do great work for reasonable cost. They had to file for the permit and the electric company came out and verified before work started. On install day the power was cut, guys did the swap, work was verified and signed off, and power was restored. I wanted to upgrade to 200 amp but the power source is underground from the street so cost to trench 400' would have been mine. So I settled on a 125 amp panel. Total cost was $1600 and additional $200 for stucco patching.
The electric brothers said I was lucky that my home had not burned down yet. My 70's era home appears to have had a series of 'remodels' and the electric as seriously messed up (junctions behind drywall) and tons of uncovered splices. Don't take chances folks.
Last edited by JavaBrewer; 10-20-2015 at 10:15 AM.. Reason: Corrected the cost figure
Old 10-20-2015, 10:11 AM
I bought a BRAND NEW Zinsco main breaker box (full of breakers) at a garage sale for $50 ... WOW! What a score! I wanted to replace the old fuse box in my 85 year old home.
I asked my good buddy (Card Carrying 25 year IBEW Electrician) to help me perform the install. When he saw the garage sale Zinsco he picked it up and threw it in the trash. His reply was: "you wasted $50 ... but I may have just saved your life ... I like your wife and kids too!"
Old 10-20-2015, 10:26 AM
Detached Member
Hugh R's Avatar
Do it yourself, house burns down, insurance company denies claim.
Old 10-20-2015, 10:44 AM
Fear of burning your house down is as irrational as not pumping gas in case your car explodes at the pump.
The probability is minuscule, and it approaches zero if you know what you're doing. And it's not rocket science.
Old 10-20-2015, 11:15 AM
You might have missed the faulty breaker part. They melt instead of tripping and will continue to allow electricity to flow through. It has nothing to do with installation methods or mistakes
Old 10-20-2015, 11:27 AM
Change out the main panel is in the works for you, my friend. I am not kidding. Zinsco have a known track record of not working properly and many houses have burned due to faulty breakers made by them. Many of the barkers have been found melted together and not tripping or cutting power allowing unsafe amount of electricity into the home. It will not pass UL approval today due to their faulty design. Look into it.
I haven't done anything yet but I am looking for a local independent electrician.
But, I was just wondering....The breakers that I purchased are manufactured by Connecticut Electric and are replacements for Zinsco. The package says UL Approved. Does this mean that they are an acceptable replacement for Zinsco?
Also, is a main breaker for 200 amp service the same thing as the double 100 amp breaker. My current main breaker has two switches that both say 100, but the switches are green. When I looked up Connecticut Electric website they list main breaker separate from the one that I bought even though the one I bought looks identical to what's in my box now.
This is only for my education and I intend to replace the whole box this month.
Old 10-21-2015, 09:20 AM
Does the breaker you bought have a metal post between the two switches? If used as a main it either should or you would have to connect the switches where the holes are in them.
The UL is only for it's approval to be used as a electrical switch, not necessarily how or as a replacement of etc.
I'd stay miles away from any replacement for a faulty panel. The Zinsco's or Federal Pacific panels just simply should be removed and trashed. The technology /construction of new panels is miles above what it once was
Old 10-21-2015, 09:28 AM
I was responding to another comment regarding 'doing it yourself and burning your house down', not leaving a defective breaker in place.
This is a repair I would do myself, and I would sleep soundly afterwards.
Old 10-21-2015, 10:23 AM
"So Mr x... is it true that you installed the electrical panel in the home that caught fire and killed the Smith family?"
..."Well yes your honor, but that was 20 years ago...and...and... I am pretty sure that I did it right...."
"So Mr. X, can you inform us of your formal training as an electrician? Doing it properly means you pulled permits and had it inspected, correct...?"
..."Um, well, no, but I am really good at doing stuff myself..."
Then, you simply write a check for your entire net worth to the other parties lawyer...
I do a lot of my own electrical. It isn't that difficult. Heaven forbid something happen, little risk down the road for most things. I have put in additional electric breaker boxes next to a pre-existing...
Not sure I would risk my life working on live lines from the street to avoid a $1500 charge...
Old 10-21-2015, 10:44 AM
Who said anything about live lines?
I'm an EE, pretty sure I could do it, live or not. But I would pull the meter.
How you go from installing a new breaker panel (on a drywall backing, by code) is beyond me.
I stand by what I said. None of the 600 volt machines I have wired over the years have blown up or caught fire. I don't think 110 V is about to scare me.
Old 10-21-2015, 02:27 PM
Its 240 BTW. I don't know what kind of electrical "stuff" you design, but I am sure you know what you are doing, if not, you wouldn't tear into your own house.
I don't know what does being an EE have to do with wiring up a main panel? I have done a ton of work for a a bunch of NASA or JPL engineers or physicists over the years. As a matter of fact, I am in the middle of one right now for some head honcho at JPL. I always remember this conversation with a home owner. He was the really, really smart physicists. My electrician and I were talking about grounding to water pipe and the Ufer ground. He sticks his nose into our conversation and said, " I should know that method and the code required, I have two PhDs in Physics." We both stopped and looked at him and said what do you suggest so we pass code?" Crickets were all we heard. He continues to mention his PhDs for some times after that.
the whole point is to do the electrical work to building code. Not only it is safe, but if something happens, the blame is shifted to the mfg and not the installer.
Old 10-21-2015, 04:00 PM
i understand what you are saying c4s.it's easy, the new panel will be larger than the old panel.
if you do it right, it won't show through the drywall.
Chris
the more i learn, the less i know
Old 10-21-2015, 04:34 PM
Geeze, it appears that my power outage and subsequent breaker failure has stimulated some interesting conversation.
Regarding building code...I intend to have my repair done to updated building codes.
Next Question: Does anyone have a recommendation on brand for the new box (i.e., Square-D, etc..)?
My setup is fairly simple. I currently have 200 amp service and I believe that this is adequate for my home. The only future major electric that I plan to add is a hot tub and that will be mostly gas heated with electric pumps. I currently have electric dryer, electric stove, and electric oven and will some day convert to gas stove. My house was built in 1949, has romex wiring through out the house with 50% 3-wire romex with ground. My breaker box is mounted on the outside of the house with the electric meter at the top.
I really just wanted to replace my main breaker but this new info that I have added should encourage some more arguments.
Lastly, just to keep it interesting, here is a photo of our breakers at work - 480V
Where I live the breaker has to be mounted on drywall. All I was trying to convey was that I would follow the local code.
Old 10-21-2015, 05:05 PM
Its 240 BTW.
It's 110 to ground/neutral, which is the typical manner people get a shock, (line to line shocks are uncommon) as opposed to our 600 v industrial lines. Somewhat more dangerous.
I have no further comment; Hugh was afraid someone would burn their house down, I don't agree. Yes, turn the power off, follow the code and it will be fine.
Old 10-21-2015, 05:08 PM
it's 240 phase to phase.
so you know a dry room,
can you wire a three way?
it's gonna take at least 6 hours.
keep the fridge closed.
i'm more familiar with seimens over square d.
Chris
Old 10-21-2015, 05:18 PM
Band.
Hugh is absolutely right, which is why I didn't rewire and pull new cable through the conduit in my 87-year old house.
I wish I had
, because it would have only cost my about $500.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 10-21-2015, 05:42 PM
Band.
I did adjust the timing on both my 911s, which (if done poorly) could (over time) grenade a 5-figure engine and conceivably kill a passenger riding with me if it locked up and caused us to crash.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
Old 10-21-2015, 05:45 PM
Originally Posted by billybek View Post
I got rid of a Federal Pioneer panel for the same reasons listed as the Zinco panel. The old Federal panel had almost no room in it compared to a new modern panel.
I saw your post with "Federal Pioneer" and wondered if you meant "Federal Pacific." As it turns out, Federal Pioneer panels are just re-labeled Federal Pacific panels that were sold in Canada. "Stab-Lok" breakers are the culprits. Apparently, the guys at Federal Pacific "faked" the UL certification on the panels and sold them without having them tested.
Pretty ballsy.
I just bought an apartment complex that was built in 1967 and I have to change out 81 Federal Pacific breaker panels as a condition for obtaining property insurance. I have 60 days to get it handled and It's going to be a $52k fix (materials and labor). Money well spent.
Old 10-21-2015, 05:49 PM
