If it were a horse I'd shoot it...
![]() ![]() From the write-up: "Not stock. Up front, the entire frame/body of the car was removed and a one-off subframe was fabricated with 6 mounting points - very stiff and very light. The stock a arms were kept, along with stock torsion springs and strut assemblies. The strut assemblies were shortened approx. 4" and new late model lowered VW strut inserts were installed. The arms and torsion assemblies were brought in 10", and raised 6". Why narrow the front end 10"? Because we can. Why raise the front end 6"? This is the quickest way to get a 911 to a respectable height. The result is a completely stock handling front end, tucked front wheels. Out back, the rear end was dropped approx. 6" using the stock arms and rotated, notched springplates. A section of rear frame was notched to allow full movement of the rear suspension. Engine and transmission were raised approx. 3" for clearance. Transmission is an early Bay Window type 2 002 IRS transmission. Axles were modified to accept type 2 CV's and stock Porsche CV's at the hubs. New stock shocks in the back are installed. Steering rack was replaced with an 11" unit, with 1.5 turns lock to lock - super quick steering. Engine is a 1776dp with approx. 6500 miles on it. Engine tin is handmade from a surplus of Bosch aluminum signs. Shifting linkage is custom, with a type 1 shifter assembly, an off the shelf shifting box, and modified 911 shifting linkage - flawless shifting. Pedal assemblies are all CNC aluminum units, with dual brake reservoirs/master cylinders. Clutch is hydraulic. Accelerator pedal is also a CNC unit, with a custom cable tube installed. All new brake lines, hard and soft are installed, along with hydraulic lines for the clutch. A new wiring harness was also installed. All lights and turnsignals operate as they should. Original Fuch wheels were powdercoated white and installed with new staggered tires front and rear. Up front, calipers are new, out back, type 1 calipers are new. Lug nuts are also new black anodized aluminum pieces."
'70 911T (AKA Bottomless Pit) - Undergoing restoration '13 Audi A4 1.8T - Surprisingly fun means of getting to work |
It's pretty easy to forget that not long ago a rusty tub was something you almost couldn't give away.
People tend to do stupid things with cheap cars. |
Dog-faced pony soldier
So buy it and fix it your way.
Did you get the memo?
Rat rod meets stance stupidity. Both are things that make me confused.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
resident samsquamch
"...good ride height, but certainly not great ride height..."
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
No doubt a finite element analysis was done beforehand. Quote:
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Run Forrest Run!
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Model Citizen
Front track narrowed for "Hoffman Like" stability.
resident samsquamch
Well played!
Edministrator
$30K car + $20K in parts + $25K in labor = $3K car. Success!
Good post? Leave a tip! O - $1 O - $2 O - $3 |
WTF??
I need eye bleach.
Unregistered
There ain't no limit to stupid.
Needs some casters on the front.
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
Neil '73 911S targa Last edited by Neilk; 11-03-2015 at 07:16 AM.. |
Model Citizen
I think this car has been here before. I remember the chain holding the battery. Nifty!
That build has to be approaching 5+ years old. I bet that tub was essentially free, so at the time they were saving a classic car body from going to scrap. Only recently have these cars gone for ridiculous money, and if the trend stays on course then perhaps one day this car will be restored to original. Personally I am a little sad to see that the values of these cars are driving people away from using them and modifying them. Seeing something different than stock is part of the charm of car culture to me.
1984 Porsche 911 |
Needs way, way more engine, a set of wheelie bars and a parachute.
If you're gonna go nuts, stick to your theme. angela
Hello http://forums.pelicanparts.com/off-topic-discussions/1102514-we-lost-amazing-woman-yesterday.html |
Edministrator
Patina needs a clear coat.
So does the chain on the battery keep it warm in the winter when it crosses both leads?
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
