Air Medal or two
afterburn 549's Avatar
Size of Air Filter for Cubic feet of air (Under Boost)
Thanx for looking-
The turbo aspect throws me -
Engine - Twinn cylinder, water cooled - 98 x 70 mm , Turbocharged 1056cc , 4-stroke.
Boost is around 20 lbs max . 9000 RPM
I have no idea how to figure it out when compensating for the boost.
The question is - what size air filter to use for CFM drawn or pushed?
Thanx!
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 02-10-2016, 10:29 PM
Arizona_928's Avatar
Trick question. Run no air filter
V twin? sounds hand built. I would run any cone filter that can fit directly to the inlet of the turbo.
dolor et pavor
Copyright
Old 02-10-2016, 10:42 PM
Hmmmm I probably put too many sig figs for the application, but it should get you into a ball park.
Try
([(64.441 in^3) x (9000 RPM) x (1.360 atm)]/3456) = 230 cfm rounded up
1.360 atm = (20psi/1)/(1 atm/14.7psi) at sea level.
dolor et pavor
Copyright
Last edited by Arizona_928; 02-11-2016 at 04:12 AM.. Reason: edit: at one atmosphere not bar
Old 02-10-2016, 11:46 PM
weekend wOrrier
Did a guick google search. Does this help?
Turbocharger Compressor Calculations
Old 02-11-2016, 05:04 AM
Max Sluiter
Flieger's Avatar
Use the biggest air filter you can. Less restriction is better.
Old 02-11-2016, 07:47 AM
