How to secure a large beam to the wall?
Well, we found a timber for our mantle for $100 vs $950 the place downtown had. Mrs Rocket says its heart pine vs oak, but I can live with that to save $850.
Now the question is how to mount it. It's 8"x8" and I need to go through a 1/2" of drywall and 3/4" of ship lap to secure it. I bought some 1/4 x 10" lag screws I was thinking of countersinking in at an angle from the top and maybe bottom. There will be very little weight on it but it does weigh quite a bit itself. So, any other ideas to install it and cover the holes?
I see you
If I do the arithmetic you'll only have 1" of lag screw go into the stud. I don't think that will hold against the rotation downward force. Are you planning any knid of other support underneath the mantle?
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
You do not have permissi
I was looking at bathroom grab bars and saw these WINGITS | Products
'Rated up to 600 lbs. in drywall and tile' ...umm...maybe. That will need more than those dinky 1/4" screws. Go 1/2" or more at least. And a lot more penetration into studs if possible. Or invisible hangers from behind. Hollow it out to drop weight. Plug holes flush and brush paint it grey to match. |
Drill from the bottom at a 45 degree angle, and a couple from the top, same thing.
Put you bowling trophy over the hole. Or do it like a headboard. Rout a 45 degree angle into the beam, then hang from a corresponding board attached to the wall. Or three 3/8" lag bolts with the heads cut off. Drill the mantle to suit and slide the beam onto the bolts, put some construction adhesive on the back.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." Last edited by 1990C4S; 07-04-2016 at 05:16 PM.. |
Run smooth, run fast
Why not install it like a floating shelf so you don't have to mess up the face of the beam?
You won't really need the anchors shown here since you're going into the studs, but this is the general idea... I'd recommend 1/2" or "3/8" X 12-14" lag screws, cut to about a 7" exposure after you get them in: How to Install a Floating Mantel | how-tos | DIY
- John "We had a band powerful enough to turn goat piss into gasoline." Last edited by Heel n Toe; 07-04-2016 at 05:22 PM.. |
Platinum Member
No reason to show fasteners, I would blind mount with a Cleat, like this:
![]() Or use Pipe Flanges and pipe nipples lag bolted to the wall, 3 or 4 like this: ![]() And drill/recess the back of mantle to fit. Last edited by dad911; 07-04-2016 at 05:22 PM.. |
Navin Johnson
Return those lags...
mount a cleat on the wall, route out a pocket on the back of that beam, and hang the beam on the cleat.. crappy 20 second sketch...
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Platinum Member
When using a mantle like that to cap or embed in a stone veneer, I have bolted flat steel to the back, cut a little longer than the mantle is tall. Then screw the steel to the wall above and below the mantle, stone/grout hides all.
Slackerous Maximus
This. Take your time, find the studs. 8 screws with 2 inches of depth into the studs will hold quite a bit.
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
Great ideas gents. Thanks!
Google french cleat...
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Information Overloader
Remove one or two pieces of ship lap above the mantle piece, carve away the drywall over the studs to receive the flat stock so it is flush, drill pilot holes in the studs and in the back of the mantle. Lag bolt flat stock to the mantle. Raise the mantle. Bolt flat stock to studs. Replace ship lap.
Rabbet out a 3" x 3" x 4' from the bottom backside of mantle. Lag a 3" x 3" x 4' onto wall catching 3 studs. Mount 8x8 onto 3x3 and lag up through the 3x3 into 8x8.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
I'm trying to figure out a way to encorporate fiegallon buckets into this project.
Use stainless steel cable to float the beam in mid air, suspended.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
JR |
