Recreational Mechanic
Trailer quesiton: Anyone use "Tire Block" over the wheel tie downs?
I just got an open trailer for my Elise (pic below) and trying to figure out the best and easiest tie down solution.
Has anyone used an E-track based over-the-wheel tire block solution? Several of the trailer accessories sites advocate them and say they work great. The lack of lateral strapping makes me a little nervous but if it works it works? Any experiences? ![]()
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
+1
That's what I found with my 930. |
That's my problem...clearing the fenders with the thru-the-wheel setup. Thanks for replying.
also a lasso strap used in conjunction w/ a direct hook ratchet eases tie down a lasso strap has a D or O ring integrated in the working end, the bitter end of the strap then goes thru the ratchet, run the biter end thru the wheel then thru the ring then thru the ratchet.
http://www.macscustomtiedowns.com/product/pro-pack-premium-tie-down-kit-with-axle-straps/Package-Deals Sent from my SM-G900V using Tapatalk
RETIRED
I use chocks and tie downs both.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
We use over-the-tire strapping and it has worked well without screwing with carefully aligned front suspension. Never had any problems but never crashed the trailer either. We used to cross-tie from the jack points but they would sometimes loosen with a little car suspension movement. The over-the-wheel straps have been solid.
2009 Cayman PDK With a few tweaks 2021 Cayman GTS 4.0L 2021 Macan (dog hauler) |
Thanks Bill. The blue one looks easy but no protection from rubbing on the wheels? Looks like you've tried them all!
The blue one is for a chassis attachment or for going to the thru the wheel straps, the direct fit ratchet can be used w/ either that strap w/ clip on end or w/ a lasso strap, wish I had a pic of the lasso, it's just like the blue w/ clip on end except the end is a D ring, you make a noose going thru the wheel then the D ring and avoid the complication of the short thru the wheel straps the padding on the wheel straps isn't really necessary. Thru the wheel doesn't work well w/ my car because the brake rotors are so large.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
It looks like the rear will work with your proposed over the wheel tie downs. Why don't you buy the ones with lateral straps?
Sizing requires adjustable wheel nets, all the ones I find have buckles on the front of the wheel (adjusting the net length) that would rub against the wheel I'd think and scrape it up. I think the best solution is to have a set custom made, Mac's does that, not sure on the cost but then they'd be stitched to my wheel size with no adjustable buckle banging around.
Here's the setup I ended up doing. Man installing those e-tracks is no small task....I put in 100 bolts and I still have 36 to go (I ran out, will finish next weekend). I got enough in to test the car on the setup:
Looks great. I'd wait until the tires are cold before rolling it up on those tracks unless you can put something between the tire/track. I have aluminum diamond plate on my trailer and it will leave a imprint on hot tires.
But on second thought maybe it doesn't really matter to the tires.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ Last edited by URY914; 07-31-2016 at 03:55 PM.. |
