Our neighbor's snowblower...
Our neighbor has a snowblower - see pics. It backfires to the point where it is unusable.
This gal has taken the carburetor apart. Cleaned the jets etc but not replaced any parts. It is a Honda 4 stroke. Has put premium gas in it. I said did you clean the air filter? She said there isn't one. She has replaced the spark plug. She said a shop manual is $40 and does not want to spend the $$ on that. If she has to sell it with the backfiring going she will. I said it I would put the situation to you all. Any ideas? ![]() ![]()
The Unsettler
Owners manual
http://cdn.powerequipment.honda.com/pe/pdf/manuals/00X31V106270.pdf Needs to be fixed before sale. I agree, she will eat more than the $40 for the shop manual.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" Last edited by stomachmonkey; 08-11-2016 at 11:10 AM.. |
A new carburetor can be had for < $20 (I found it for $18.12 on boats.net)
-John '94 968 Iris Blue '85.5 944 White - Rally Cross and wrenching practice '84 944 Gemini Grey (gone, but missed...) |
Clean idle circuit and pilot jet......20 minute job..No need for a manual, can find help online..In the future, if sitting more than a few weeks, add Stabil to Non-ehanol fuel, shut off fuel valve and run till it quits.....
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
Sure could not hurt to check the valve adjustment either .
No left turn un stoned |
Thanks all. I have downloaded your responses and passed them on....
Carb cleaning video is here: https://www.youtube.com/watch?v=4i14aB6g798
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." Last edited by 1990C4S; 08-11-2016 at 02:11 PM.. |
canna change law physics
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Ethanol-free gas stations in the U.S. and Canada
Non Compos Mentis
All of my small engines/yard equipment get nothing but 100 LL Avgas.
Nice to have them start on the first pull, even after sitting for long periods. No Stabil necessary. |
She should use a name brand premium fuel...
Shell V-Power NiTRO+ premium gasoline in Canada does not contain ethanol.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Feelin' Solexy
Knowing absolutely nothing about this particular engine, backfiring says timing to me. If this is a magneto ignition I would look to see if the woodruff key is bent (not uncommon on small motors that might get a big torque load eg hittng tree stump with your lawnmower blade), this could result in the timing being off.
Grant In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S |
unsafe at any speed
Backfiring on this model...Check for a broken rocker arm. Exhaust rocker arms crack, and then won't fully open the exhaust valve. since combustion gases can't escape they pop back through the intake. have seen this on several of the small Honda engines.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 Last edited by wswartzwel; 08-11-2016 at 07:59 PM.. |
Bland
The plug wire is disconnected.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
GWAD........The advice you get on the Internet is exactly worth what you pay for it........
Just want to give closure to this thread. This snowblower will run in a more efficient manner now I asked about whether the snowblower was fixed. I gotta give credit to the gal that owns it. She kept going to another neighbor and finally he said to check the fuel flow.
The owner concluded that the fuel supply was partially plugged and once the lines were cleaned out it ran well. Thanks all for the suggestions....
Team California
The Occam's Razor theory wins again.
Denis |
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
