Kantry Member
oldE's Avatar
Alignment of Engines on Airliner
Watching a four engine aircraft go over this afternoon, I noticed something odd in the contrails. The right side outboard engine and the two inboard engines seemed to be parallel. The left outboard engine was directing its exhaust a few degrees outboard. The contrail from that engine diverged from the other three for a while but converged again after a few seconds.
Was I observing a misalignment of the left side outboard engine?
It seems to me having an outboard engine directing its thrust at an angle to the center line would mess with the trim.
Best
Les
Best
Les
Old 10-27-2016, 12:02 PM
Best
Les
That divergent one is the chem-trail the government is using to kill us all off. You know the random poisoning of everyone even themselves and their family.
Old 10-27-2016, 12:41 PM
You fool! The weird one was the only actual engine, the other THREE were the chemtrail machines!
Why only have one chemtrail machine per plane? That's not efficient!
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 10-27-2016, 12:49 PM
Preferred pronoun:Maestro
Norm K's Avatar
Don't tell Hillary, as this is supposed to be a secret, but we people behind the curtain have been inoculated.
_
When in doubt, use overwhelming force.
Old 10-27-2016, 12:51 PM
Jolly Amaranto's Avatar
They are using thrust vectoring on the outboard engine to adjust for a jet stream cross wind. On the Airbus 380, one of the flight attendants has to don a special skin tight silver jump suit and crawl down a passageway in the wing root. Once there she has to turn a large crank to adjust the engine pod to redirect the thrust.
Old 10-27-2016, 01:02 PM
You do not have permissi
john70t's Avatar
Chemtrails! (or probably just an updraft)
Old 10-27-2016, 01:09 PM
abisel's Avatar
Probably not a misalignment but rather the effect of winds aloft and the vortices created by the wings at the wing tips.
Vortices will cause the outboard exhaust contrails to move outboard and then back inboard. The inboard engine exhaust contrails are not effected by the wing tip vortices and actually move down from the flight path of the aircraft.
Winds aloft (a crosswind) can cause what you see. Three are parallel but one is divergent outboard but then comes back inboard.
Old 10-27-2016, 01:20 PM
Norm K's Avatar
Are spectators allowed?
_
Old 10-27-2016, 01:27 PM
recycled sixtie's Avatar
I am surprised nobody has said this. It needs an alignment.
Old 10-27-2016, 01:40 PM
Used to be Singpilot...
Location: Sioux Falls, SD is what the reg says on the bus.
I spent 37 years making those.
Think boat wake.
Old 10-27-2016, 04:24 PM
weekend wOrrier
I am John Conner from the future and you have brought up an interesting question. Shortly, a reprogrammed terminator unit will show up at your house on a motorcycle. Do not be afraid. Jump on the back. Your life depends on it.
Old 10-27-2016, 05:16 PM
john70t's Avatar
The winglet apparently reduces the vortices, and thus less overall drag.
https://en.wikipedia.org/wiki/Wingtip_device
Old 10-27-2016, 05:29 PM
Retired in Georgia
Robert Coats's Avatar
I've got five kids, an Italian wife, and I (used to) write about lawn mowers. You think you have problems?
-Robert Coats
Old 10-27-2016, 06:20 PM
DanielDudley's Avatar
Somebody forgot to check the lug nuts. The wingnuts are OK.
Old 10-28-2016, 03:53 AM
Kantry Member
oldE's Avatar
Glad to see some of you still have your carefully honed sense of humor.
Since I was not directly under the aircraft's path, but to its left I am guessing my viewing angle lessened the apparent divergence of the right outboard engine's contrail and increased that appearance on the outboard engine on the wing closer to me.
Thanks all.
Best
Les
Best
Les
Old 10-28-2016, 04:06 AM
Originally Posted by Robert Coats View Post
Well done.
Old 10-28-2016, 05:15 AM
