Small Block Chevy does NOT like the Cold.
I rebuilt the small block chevy not too long ago to put in my truck. Pistons, rings, bearings, cam, valves, ignition, and a quadrajet rebuilt by Cliff.
Ever since it has gotten cold, it feels and sounds like a mis-fire until it warms up all the way. I pulled the plugs and they're OK, if a little rich, but still ok. At cold start-up I can hear a mis-fire out of time bang,clank, in the passenger side long tube header, but then after it warms up, it goes away and sounds fine. Any ideas where what to check? I'm thinking maybe ignition wires need to be sorted a little less tangled? It's only on that one side.
Scot 78 911SC coupe, sold,, 2019 Macan S "my friends all drive Porsches, I must make amends.." |
D idn't E arn I t
I'd think exhaust leak or an intake manifold leak- without being being there to hear it myself.
Retorque everything.
In the movies only bad guys sleep in king size beds. |
Check it out in the dark around plug wires and look for arcing
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS |
cool, thanks, good ideas to start
If your wires were arching you would most likely have the problem all of the time. What type of choke is on the car? It might not be adjusted properly. Did you check the choke before starting the car when it is cold and make sure it is actually closing all of the way?
89 930 Cab Black 11 Cayenne |
D idn't E arn I t
that popping is air getting into the system somewhere...
unsafe at any speed
Lean misfire perhaps since the engine is still cold. Does it pop back through the carb? Carbureted engines don't run well until they are warmed up. Fuel injection has spoiled us.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
For sure. I used to have to sit in my El Camino freezing my butt off trying to get it warm enough to idle when it was really cold. I converted to throttle body FI many years ago and never look back. It fires up in a second when it is zero or 110. It is the best upgrade on that car ever. Equal adding the Griffith's AC system on the 911 as the best upgrade ever and having a car I can drive in the heat.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
The quadrajet is and always was a piece of crap.
JPIII Early Boxster |
We always called them Quadrajunk.
Randy '87 911 Targa '17 Macan GTS |
non-whiner
Describe your cold start procedure. What does it take to get the truck to start when it is cold?
"Too much is just enough." |
Pump the pedal all the way to the floor 3 or 4 times B4 turning the key. Make sure choke is adjusted properly. Cold engines require more fuel. Ur not getting it.
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
I have some cars that miss on cold startup, I attribute it to plugs being wet from either condensate, coolant, or fuel Since it doesn't persist I haven't figured it out totally. I suspect it's water because when it quits missing I immediately see more steam out the exhaust.
72 914 2056: 74 9146 2.2: 76 914 2.0 |
So, I'll try richening the idle mixture on that side. I remember leaning them both a while ago.
Cold start procedure, three or four stomps to set the choke , then it fires right up in just a few cranks !
Preferred pronoun:Maestro
Sounds like someone opened one up as a novice expecting to find a parts count similar to that of a Holley and instead found a far more complex fuel delivery apparatus. Undeterred, disassembly of this marvel of fuel atomization continued until they were so hopelessly in over their heads that they threw the entire lot of parts in the trash and jumped on the "Quadrajunk" bandwagon. Shame, because if they'd taken the time to really learn about them they'd have discovered that the Quadrajet is probably the finest street-use carburetor ever designed.
![]() _
When in doubt, use overwhelming force. |
Thanks Norm, that's what I was thinkin
And if yours was built by Ruggles my guess is that it's not the cause of your recent difficulties. He's not perfect, mind you, but there's a pretty good reason you have to get in line if you want him to rebuild your Quadrajet.
Good luck! _
Fleabit peanut monkey
Was thinking exhaust leak that seals off after heat expansion at first blush. I have owned a car with a cracked exhaust manifold that made boatloads of noise until warm then ran (sounded) like a sewing machine. Mine only sounded bad - it did not "feel" like a miss.
Carbureted intake manifold leak could create a miss-fire or weak-fire at a specific cylinder. Given heat that is in the 200F (intake) vs 500F (exhaust) range I am not seeing 200F heat sealing off an intake leak (intake to head) that is big enough to create a noticeable miss. Just talking. OP could always try the carb/brake cleaner spray test.
1981 911SC Targa |
I have no argument.
1981 911SC Targa |
