gwood's Avatar
Originally Posted by afterburn 549 View Post
Ok
Now if i had an old V8, right about now I would be wishin a vendor would start selling a Flat plane crank and cam kit for it.
Will this ever happen?
Stevie's Crazy Garage. (Good name.)
Old 02-03-2017, 08:46 AM
Air Medal or two
afterburn 549's Avatar
Thanx for the name drop!
Ahem 27 grand?
cough.
sputter.
Old 02-03-2017, 09:38 AM
Originally Posted by cockerpunk View Post
every inline 4 ever made has a flat plane crank.
Yamaha has built cross plane in-line fours for a number of years. They started with their Moto GP bikes and now use them in street bikes as well. Their big advantage is that they do not accelerate/decelerate all four pistons at the same time.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 02-03-2017, 10:14 AM
Air Medal or two
Thanx!
Now there is something I did not even think of !
Old 02-03-2017, 10:17 AM
Misunderstood User
Originally Posted by tcar View Post
Cross plane cranks need counterweights.
Flat plane cranks don't have counterweights.
Ford uses a harmonic balancer to smooth out the vibes.
Going back to my college days in the early 70's, I remember learning that the inline six is naturally balanced. 8 cylinder engines , straight or v designed are not - they need external balancers.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 02-03-2017, 12:29 PM
That's true - inline sixes are the only engines that come up all zeros. Used to be about the most common engine made because of that. Packaging has kind of hurt it, though - it's just so darn long. Lots of crank twist in the more powerful ones, too.
Mercedes, however, have developed a new I-6, variants of which will power all of their cars in coming years. Everything old is new again...
Jeff
'72 911T 3.0 MFI
Old 02-03-2017, 01:01 PM
Air Medal or two
https://www.svtperformance.com/2015/09/22/news-flat-plane-crank-conversion/
Old 02-03-2017, 01:10 PM
Air Medal or two
I am always a little bit surprised that the ford six with the exhaust and intake all on one side was not promoted as a turbo version.
Old 02-03-2017, 01:15 PM
FUSHIGI
I believe any V-12 angle satisfies the "all zeros" criteria too as it is essentially two inline 6's on one crankshaft.
Old 02-03-2017, 01:30 PM
Bill Verburg's Avatar
Ok
There's really no need
the F/O on the modern Chevrolet LSX series motors and the Ford Coyote reduce the consecutive side firing issue to just 1 pair on one side. The LSx fires #2 and then #6 consecutively on the right side while the Coyote fires #8 & #6 consecutively on the left side. There is still 90° o crank rotation between them. You can use the same TriY headers as the NASCAR boys do to mitigate even that. My personal favorite is the DOHC Coyote 5.0, though the LSx have their charms, its really hard to top the cam timing variability of a DOHC motor, The LSx substitue displacement and otherwise excellent design for the sophistication on the Ford motor.
The older V8s will have 2 consecutively firing cylinders on each side, crank torsion and vibration is up over that in the modern V8s but you can still live w/ it just not rev as high or as often. here the Tri y exhaust really shines.
The irregular firing pulses do have their benefits, among them is the ability to put power to the ground, HD V twins were notoriously good at powering out of a corner on dirt, The Yamaha V4 w/ crossplane crank does the same on pavement, not sure that this is applicable to 8 cylinders though but it sure does sound good.
Bill Verburg
Old 02-03-2017, 02:16 PM
One of the older tricks in the H-D flat track arsenal is to re-set the cam timing (very easy on the XR750/Sportster platform) to make it run as a "Twingle". The Triumph, BSA, and Norton guys did this as well on their parallel twins. The parallel twins were turned into a "split single", or "twin single" ("Twingle") wherein both jugs fired together. The H-D's necessarily have a 45 degree split, but the idea is the same. Better traction on really slippery clay. I saw Chris Carr running this setup on his XR750 in Sturgis one year, when he was riding the local half mile while recovering from a broken leg. Very easy to pick his bike out of the crowd.
Jeff
'72 911T 3.0 MFI
Old 02-03-2017, 02:26 PM
Fast Acting, Long Lasting
every inline 4 ever made has a flat plane crank. there isn't any particular magic to them.
the sad things is the engineering that makes the GT350s motor rev so high isn't the fact that its a flat plan crank, but very good valve train engineering. if i was on the valve train team, id be pissed the marketing guys keep trying to say the engine is magic because its flat plain
Detroit Diesel 4-53 had a 90 degree crank because it was a 2 stroke.
Eighteen ways to burn fuel.
Old 02-04-2017, 11:14 AM
least common denominator
scottmandue's Avatar
I have nothing to add but would like to thank afterburn for posting this and all you brainy guys for posting.
I have heard the new Mustang and was wondering how they got that sound.
Carry on.
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 02-04-2017, 11:28 AM
Air Medal or two
I have a rudimentary skill set, but others with more understanding have helped.
Plus, all this has made me study the homework they have posted, plus some I have found.
Thanx guys .
Old 02-04-2017, 12:57 PM
The HD 'twingle would still sound odd
HD does use a 360° cranks like Dudacti but the cylinders are 45° out of phase
Norml HD firing pattern is 315-405-315, 'Twingle' is 45-675-45-675
Ducati and British vertical twin will be an even fire 360-360-360, 'Twingle version is the same
Bill Verburg
Old 02-04-2017, 04:34 PM
Doug Crossman
#92 1992 964 PCA G class
#902 1979 911 PCA 911 Cup
96 993 Targa
Old 02-05-2017, 08:23 AM
