LiFePO4 Lithium Cat Battery - Head Scratcher
Guys \ Gals - What a head scratcher! I've been contemplating a move to these Lithium batteries on my daily driven Mazda (which has a turbo Miata 1.6L engine) but on the fence.
On one hand I've read so many scary stories about these batteries exploding from even being on the correct trickle charger (over charged).
On the same hand I've heard some last from weeks to months and longevity is not quite there.
Many say its really still relegated for a track or weekend auto-X car not a daily driver.
The basic goal is to try some new technology and save 10 lbs from the AGM lightweight battery I currently use...but as three times the price is it worth it?
What says you?
Yasin
P.S: I found these pictures on the Subaru forums from a member that had two (2) Lithium battery failures in his car:
First battery:
Second battery:
Old 02-16-2017, 03:48 AM
canna change law physics
red-beard's Avatar
The batteries that explode are not LiFePo4. They are Lithium Cobalt Oxide(LiCoO2) or NMC or NCA.
LiFePo4 is the safest of the readily available batteries. That said, you need to buy a good quality battery with a good PCM (Protection circuit module). UL type testing is essential to getting a good quality, safe battery.
These guys make high quality LiFePo4 batteries. https://www.nexgenbattery.com/12-volt-battery
James
Red-beard for President, 2020
Old 02-16-2017, 04:52 AM
White and Nerdy
Tervuren's Avatar
If you're worried, make sure you have a system that monitors voltage of each individual cell and controls charging and discharge cut off accordingly.
Old 02-16-2017, 04:54 AM
red-beard's Avatar
A good PCM/BMS will not just monitor but will balance the cells. Most of the cheap batteries don't have a proper BMS. And constant voltage, lead acid charging circuits are NOT ideal for these batteries.
James
Old 02-16-2017, 05:02 AM
(the shotguns)
berettafan's Avatar
no it is not worth it.
lipo is crazy unstable.
Old 02-16-2017, 05:15 AM
wdfifteen's Avatar
Good info. I've been contemplating an Anti-Gravity battery for my Turboencabulator XLC.
Old 02-16-2017, 06:24 AM
red-beard's Avatar
What are you talking about? Except for lithium titanate, it is the MOST stable lithium battery.
James
Old 02-16-2017, 06:28 AM
red-beard's Avatar
Grimsley rods are another worthy upgrade. Not as much power as the Tunis units, but far more stable and easier to install. A much higher quality product.
James
Old 02-16-2017, 06:30 AM
(the shotguns)
berettafan's Avatar
google lipo explosion or lipo fire. long been an issue. RC people know all about it.
Old 02-16-2017, 06:31 AM
The Unsettler
stomachmonkey's Avatar
Saving 10 lbs on a DD?
It's a battery, non reciprocating weight.
You'll gain what, 1 HP?
You won't even notice it.
Hardly seems worth it.
Back off the all day buffet, drop some weight, same net plus you'll save money.
"I want my two dollars"
"Brandon Won"
Old 02-16-2017, 06:56 AM
Super Moderator
cstreit's Avatar
First I was going to say if your cat needs batteries, you're doing it wrong.
...but in all seriousness - why? You'll spend 3x for the risk to save 10 lbs in a daily driver? I'm a gadget guy too, but this seems like you're fixated on having a piece of new tech without any real benefit...
Why not just go with a smaller AGM style.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 02-16-2017, 07:04 AM
wdfifteen's Avatar
Excellent! We've been looking for a high quality, stable rod.
Old 02-16-2017, 07:07 AM
red-beard's Avatar
I personally use LiFePo4 batteriers for mobile applications. LiFePo4 is the safest regular lithium battery. You might be looking at Chinese junk, which I will not trust.
James
Old 02-16-2017, 07:33 AM
red-beard's Avatar
I'm surprised cars manufacturers are switching to LiFePo4 to save weight. The weight savings over a conventional battery is more like 40 pounds. The cost I expect is the issue. And the battery companies will not like the battery life, since they make money on replacements. A LifePo4 battery should last 10-20 years in an automotive starting application.
James
Old 02-16-2017, 07:35 AM
red-beard's Avatar
What are you using for an intake?
James
Old 02-16-2017, 07:36 AM
White and Nerdy
Tervuren's Avatar
Perhaps I made some dangling modifiers; but that is what I referred to.
Old 02-16-2017, 09:26 AM
White and Nerdy
Tervuren's Avatar
I've been using them in my RC race cars without ever having had an issue.
My packs have an internal circuit cut off that trips on an individual cell hitting its limit. My charger plugs into a loom that provides charging power to each cell individually.
I'm not great with time, but I think I've had them in use for 9 years.
Old 02-16-2017, 09:29 AM
Lots of snow Porsche away
I have an antigravity I'm my Cafe racer motorcycle, mostly because of lack of real estate for installation. I am running it with a stock vr in place, made no changes to install, it has been abused and is faultless. I know balanced charging from my rc days, I don't think that's possible with these as you only have the traditional 2 posts for hook up, there is no way to read each cell.
76 911S
86 GMC K1500
78 XS750 cafe racer to be
79 XS750 because one is just not enough
Old 02-20-2017, 03:01 PM
Mike Billings's Avatar
Had the Braille GU1R in the '73 for over a year .
6.4 lbs! For the battery!
Disconnect when not in use. I don't trickle charge either.
07 911 Turbo - Pilot Sport Cup 2 ZP
96 Carrera 4 - Toyo R888r
73 911E - Hoosier R7 + twin 75's
92 Corvette - Nitto NT01
14 BMW X3 - Pilot Sport A/S 4
Old 02-20-2017, 03:14 PM
Cajundaddy's Avatar
Not worth it for a DD IMO.
I have used 5lb Shorai LI Fe batteries for motorsport. They do have limited reserve AH and require special care and feeding to keep them healthy. A well-maintained Shorai that lives on it's dedicated charger/maintainer while not driving will last 5 years easily. Run them down to 5 VDC once or twice and it's goose is cooked.
2009 Cayman PDK With a few tweaks
2021 Cayman GTS 4.0L
2021 Macan (dog hauler)
Old 02-20-2017, 03:52 PM
