Don Ro's Avatar
Originally Posted by tabs View Post
One 14 inch is shown as being SOLD for $500, the same guy has another smaller one for sale with a handle for $350.
I will let you have one of my 14 inch Woks for $495.00...never used, brand new, right from Shanghai.
And I bought 4 of them...
I wouldn't want to get between you and your making a handsome profit.
How about $80?
Don
"Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence."
- - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View
Old 03-05-2017, 12:38 PM
A Man of Wealth and Taste
tabs's Avatar
How about $80?
I will think about it.
Copyright
"Some Observer"
Old 03-05-2017, 12:41 PM
Don Ro's Avatar
Originally Posted by craigster59 View Post
This would be comparable to a Cen Bros wok...
https://www.wokshop.com/newstore/product/the-wok-shop-hand-hammered-two-metal-loop-handles-wok/
By the way, I have a wok ring but never use it on my gas stove, the wok is stable enough and I'm usually holding it with one hand while cooking anyway.
My range burner racks (not sure what they're called) have no centers so I'd guess a wok would sit well onto them.
1. What's a good size in a wok? I'll be cooking for two and will want left overs.
2. Are the bigger ones easier to shovel food up onto the sides?
3. Are the ones with wooden handles easier to manage?
Thanks for the link. Great prices for what looks to be a good wok.
Old joke:
New Chinese cook book - "How to wok your dog."
Don
Old 03-05-2017, 12:45 PM
tabs's Avatar
Old joke:
YOu need about a 22K BTU Burner to retain heat and to quickly recover heating the Wok. You also need a high capacity Range Hood..to get rid of the greasy smoke. Watch a few UTube Chinese restaurant videos and notice their kitchen set ups. Those Chinese restaurants are running 130K + BTU burners..
If you do not have the 22K BTU you have to cook in small batches and then assemble it at the end. That is why I bought a Propane outside burner..to get the heat..
14" is a good size for the home cook..per Grace Young
Carbon Steel...
The wood handle is cool to the touch. Also for the stove top a FLAT BOTTOM Wokl is easier, other wise you need a WOk RING which will move the WOK a bit higher off the flame.
Copyright
"Some Observer"
Old 03-05-2017, 01:24 PM
DanielDudley's Avatar
I don't pretend to know wok cooking at all, but I find that I add the ingredients slowest to cook first, work them all in and then stir fry. Given that I have a weak and meager regular gas stove, at the end I cover the wok and let the steam simmer the ingredients. The key is to let them simmer, then turn down the heat and let the food work its way to eating temperature, or thereabouts. I put whatever sauce I am using in just before the simmer, and flip it in.
I get easy and consistent results. For lager batches you stir fry longer, but the simmer is pretty much always the same. This is a simple way to get edible food.
Old 03-05-2017, 03:56 PM
vash's Avatar
Wok cooked food to lose weight? I'd steam and boil.l
poof! gone
Old 03-05-2017, 05:34 PM
jyl jyl is online now
jyl's Avatar
Don't spend more than $40 for a wok. Either get a cheap thin carbon (not stainless) steel one from an Asian grocery, or a thin (not thick) cast iron one. No stainless, no Teflon, no fancy woks, no stupid $500 woks.
Get a fairly large wok (at least 12"). Not because you want to fill it up, but because you don't want stuff to fall out.
Get a broad wood spatula. Shape the tip to match the curvature of your wok. Get a wire spider with a long handle. Each should cost like $1.
Prep all the food ahead of time. Cut into pieces of uniform size. Stuff that takes longer to cook needs to be in smaller pieces (meat), stuff that cooks quickly can be in larger pieces (some veg). Marinate meat if desired but pat it dry. Moisture is your enemy.
Cook each type of food by itself or with similar food. Heat oil in the wok, when the oil is shimmering and moving, add a small batch of the food, move it around with the spatula, then remove it with the spider. Batches should be small enough that it fries quickly rather than steams or boils. Meat should go from raw to brown, not spend much time gray. Undercook a little bit at this point. With a standard burner, each batch can be no larger than 1/2 cup if meat, 1 cup if veg.
Do not clean wok between batches. Add and reheat oil as needed.
When all batches are cooked, if you want a sauce then put some flavorful liquid (like a broth) with a little thickener whisked in (cornstarch, about 1-2 tsp per 1 cup liquid) in the wok and boil it until it thickens. Pour the sauce into a container.
Reheat wok, combine all the cooked batches for a final short toss in the wok. Add sauce at this time.
Do not clean the wok with soap. Use hot water and a stiff brush to knock off solid bits and let the rest of the oil and food residue "season" the wok. After a few uses the wok will be non stick.
The above is a process that will work even if you have a standard burner of 6-8K BTU. If you do have a 20K BTU burner, then you can do things a little differently.
The above is a process for stir frying. You can also use a wok to boil, steam, poach, whatever.
Old 03-05-2017, 06:10 PM
tabs's Avatar
Simmering is not Stir Frying. Steaming is not Stir Frying. What u are making is mush. Simmering is what I used to do and that is why I never thought I had cooking the yellow peoples food down.Now I have a better understanding of the process.
Old 03-06-2017, 12:13 AM
tabs's Avatar
I find the method you espoused upon to be tedious.
Old 03-06-2017, 12:42 AM
vash's Avatar
How about $80?
screw that!!
buy the wok online from the WokShop in San francisco.
i grew up as a kid in a wok family. it was the first cooking vessel i saw as a baby. ironically i dont use one now, and i'll tell you why. while my hood vent is a good hood vent; it isnt a great hood vent. you need a GREAT hood vent.
or..do it outside. we use a turkey fryer camping, and our wok is the 100% in use tool from warming tortillas to cooking dinner. and it makes the best camp sink ever for doing dishes.
somehow my brother ended up with the good turkey fryer. it has a ring that fits the wok perfectly. mine is a suckass balancing act and that makes it kinda sketchy.
poof! gone
Old 03-06-2017, 07:32 AM
Don Ro's Avatar
That $80 offer was meant as a shuck.
I'll be buying from that SF Wok store....thanks for that link craigster59 and your endorsement, Cliff.
And thanks for all the advice from you Pelican cooks.
I'll soon be woking down the path to a new way of cooking good food.
Don
Old 03-06-2017, 08:36 AM
Band.
Originally Posted by don ro View Post
i'll soon be woking down the path to a new way of cooking good food.
Smilewavy
nailed it
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 03-06-2017, 08:51 AM
vash's Avatar
awesome.
if you're ordering. add these to the list. official wok spoon/spatula. using a regular spatula is an exercise in futility. that dome shape gives me fits when it comes to a straight edged spatula. and the spoon is my kitchen favorite multitasker. it fills canning jars so quickly. they come in multiple sizes. i got these from the Clement ST chinatown a few weeks ago for my brother. i got hosed pricewise. cheaper in the main chinatown.
poof! gone
Old 03-06-2017, 09:09 AM
jyl's Avatar
No choice if you only have a standard burner and are trying to stir fry.
Old 03-06-2017, 12:45 PM
tabs's Avatar
I just stopped doing it in the house because it is slow...and will go outside with the high BTU propane burner..VASH talks about a Turkey Fryer...that is essentially the same method.
Copyright
"Some Observer"
Old 03-06-2017, 01:34 PM
tabs's Avatar
screw that!!
Screw that GO TO YOUR LOCAL THRIFT STORE...they have plenty of used WOKS. I saw a great one Carbon Steel and all for under $10. I bought an ATLAS 14 inch, flat bottom, Carbon Steel with lid for $4.00 (made in the USA).
I just do not need anymore Woks...and that is why I didn't buy that one for under $10..I did buy one of those Chinese Clay Pot cookery things that was there the same day though..I wanted to give it a try as doing something different.
I did convince some lady shopper to buy it though.
Copyright
"Some Observer"
Old 03-06-2017, 01:38 PM
tabs's Avatar
Another method is to use a Charcoal Briquet Chimney Starter putting the WOK on top to get high heat..that is considered to be more of a traditional method that was used before Gas burners.
Copyright
"Some Observer"
Old 03-06-2017, 01:46 PM
tabs's Avatar
My local Chinese/Oriental markets have those 100K BTU outside only Propane WOK Burners for around $75 to $80, and that is what the Chinese people around here buy...you can see them being used on U Tube.
Copyright
"Some Observer"
Old 03-06-2017, 01:52 PM
You mean you seen one o dem ornamental people cookin' an' it wasn't some ancient secret to them?
Old 03-06-2017, 02:02 PM
tabs's Avatar
What does Vash know about Chinese cooking was he brought up by an Italian lady or sumthin?
Copyright
"Some Observer"
Old 03-06-2017, 02:24 PM
