Insert Tag Line HERE.....
need help with web page
Hey, I need some help with a webpage i am updating.. I have some DIVs setup with two columns and when I check everything in a code editor, it displays just fine, but when I upload it to the server, it cuts off the bottom two paragraphs from the right DIV. I have the two DIVs floated left and right inside a parent DIV. I have tried several things, but i cant get it to display those bottom two paragraphs for some reason. I have tried it in several browsers also. I can email the code for you to check it out if you can help.. Help!
Thanks, Marc
Marc |
Slackerous Maximus
PM sent. I spelled your name with a K, my apologies.
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
Slackerous Maximus
btw, if the page is live somewhere, you can just send me the link.
The Stick
Without seeing anything float them both the same direction and use margin to space them apart.
Richard aka "The Stick" 06 Cayenne S Titanium Edition |
The Unsettler
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Thanks Josh, I sent it to you, and yes, I have tried clearing floats, etc. I'm sure I'm overlooking something tiny!!
Marc |
The Stick
make sure you don't have overflow hidden set. or a specific height set on the parent container.
I have tried it with and without a parent container and with the overflow set to visible, it doesn't work either way.
Marc |
I just floated them both to the left with @ 25px padding between them and it worked fine. Could not get it to work any other way.. Weird.
Marc |
Slackerous Maximus
I just went to the page and it worked fine. I was about to write to you and ask for some clarification on the problem.
Slackerous Maximus
Have you considered simply picking up a free template? You can get something that will look at lot more fresh, and all you have to do is plug in your content.
If you still have the old code, look at it and see why it wouldnt work that way..
And It still has a bunch of art work to be uploaded. It matches the home page.
Marc |
