Deep cycle battery for starting
Darn, the van needs a new battery.
This vehicle tends to see long periods (months) of not being used. I don't always remember to plug in a maintainer. So I replace a comprehensively dead battery every 2-3 years. Irritating. I'm thinking of getting a deep cycle battery (RV/Marine) this time. Idea being it will survive being left to discharge for six months. Good/bad idea? Vanagon. Group 41 battery. Mild climate, always starts instantly.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
I'm no expert, but I have four deep cycles in my motor home and the coach part has a regular truck battery. After months of sitting I can flip a switch and start the truck on those deep cycles long after the truck battery has gone dead. They are nothing special either, just Autozone off the shelf deep cycles.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Commit to the hard work and concentration of plugging in your maintainer. Why have to go through all this drama when your battery(ies) will last a maximum life time just by using your maintainer, which you've already paid for. My diesel truck now sits for pretty long periods without being started. I think I only drove it 5.5K miles last year. My last set of batteries lasted eight years. Keeping the charge up makes them last.
Marv Evans '69 911E |
canna change law physics
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
That's not the intention of a deep cycle. They're meant to have more amperage throughout the discharge cycle i.e. deeper cycle. Any lead acid battery does not like being left dead for long periods of time. Spend your effort on reminding yourself to plug the dang tender in. You know, set a buzzer on your phone or something...
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
I have a little solar panel, leave it on the dash, plugged into cig lighter. Didn't work. Grrr. Maybe I should put a slightly bigger panel on the roof and hardwire it. How big a panel would you go - want to be safe from overcharging.
I would buy a cheap disconnect switch that sits on one terminal and just cut the power when not used. Also, I would wire a small solar cell directly to battery terminals just to fend off self-discharge current.
Thank you for your time, |
https://www.amazon.com/dp/B017K6PH1S/ref=asc_df_B017K6PH1S5153287/?tag=hyprod-20&creative=395009&creativeASIN=B017K6PH1S&linkCode=df0&hvadid=198064505516&hvpos=1o1&hvnetw=g&hvrand=18220671552439794821&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9015815&hvtargid=pla-322799124658
Guaranteed to work, $32. Just don't park your van in the garage.
Lead acid batteries lose ~3% per month. Even a tiny solar panel should keep it topped up. Check to make sure there isn't a relay which shuts off the outlets when the ignition is off.
Only thing on the solar panel, I would MAKE SURE you have a 2 amp fuse inline with the 10 Watt solar panel. If the wiring shorts, I want that fuse to blow.
My John Deere diesel utility tractor has the same (fairly small sized) marine deep cycle battery in it from 2009 that I bought new then. I start it almost every day, and sometimes in subzero temps. I keep thinking I will have to replace it , but it hasn't given me ANY problems so far.
Still Doin Time
Which leads me to another little known fact. Electrons inside the battery cells escape through the vents and the case. The more premium (cost) of batteries - the thicker the case is..........
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
