Question: Epoxy Floor Prep
I having the drywall finished in my garage in preparation of new cabinets. So, I spent the whole weekend emptying out the garage for the drywallers.
Since the garage is empty, I think this is my one and only opportunity to epoxy the floors and so I will spent the next couple of weeks preparing for this. I've watched hundreds of YouTube videos and I think I've got a good understanding of the prep work (i.e., clean, clean, clean, degrease, acid etch, grind/sand the surface). My Question: You can see from my attached photos that I have a "wood" sill in this old house. This wood is always dry and I don't think it is ever getting any water from the outside but I think I should caulk it. I'm wondering if this is a) a good idea, and b) should I caulk this before doing the epoxy coating. Any advice would be great (unless you suggest replacing the wood with cement - that's not an option for me). I didn't take any close up photos but I may do that tonight. ![]()
Tape it off, epoxy up to it and then come back and caulk the joint.
Mat P 1988 911 Carrera |
I just had my floor done- they sanded it. I asked about acid etching, they felt it takes a lot of work to neutralize the acid after it was applied and any remaining traces of the acid caused the epoxy to not stick which is why they didn't use that process.
Why not put a thin silicone along the floor and cover with an attractive baseboard
El Duderino
My local hardware store carries a baseboard that is basically plastic so it is waterproof. That's what I used. Just cut it like regular baseboard, nail it in and caulk it. No risk of water absorption.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
El Duderino
If I had to do it all over again I would do the grinding method. The big difference to me is that acid etching isn't 100% even. There are going to be low spots in any floor so the acid doesn't stay in some areas long enough and puddles in other spots. The result is inconsistent finish.
I was planning on doing both acid etch and grinding. My thought is that the acid will help to remove any grease/oil that has seeped in over the years. This garage floor is 70 years old.
Do not use acid...you will never get it all out. the grinding should get out anything that has seeped/stained.
I just had the floors done here at work, They used a grinder and sanded the floors down to remove any kind of contaminate . They then painted on a grey epoxy and then sprinkled on the colored chips , after that dried over night they swept up the floor then coated it with a top coat of epoxy. There are different types of floor coating, the one you get from Home depot is not the same. They guarantied not to have hot tire pull up.
Big box stores sell water-based products. The commercial products are 100% solids - no water, no VOCs. They are much higher quality.
That being said, prep is key - just like it is with any other top coating process.
Fleabit peanut monkey
He grinds, vacs and blows. He did say acid works fine if you power-wash before and after. Before the final power wash you hose out the spent acid and broom wash with buckets of TSP.
1981 911SC Targa |
yes, that is the issue....no one goes to the trouble to fully rinse it out. The amount of water you need to fully flush the acid takes ages to dry.. you realistically need to wait weeks before you coat the floor. Everyone tries to rush it and that is where you get into adhesion issues.
I used acid on one house. Pressure washed, acid, then pressure washed again and let it dry for several days. Then two coats of S-W Armour Seal. It lasted the eight years I was there with no issues. Very tough. I'm sure it's still fine another ten years later.
Robert Callaway PCA | Early S Registry | R Gruppe 1970 T Coupe, 1990 C2 Coupe, 2007 Cayman S 1962 S90 Coupe - Gone, but never forgotten... 1985 Targa - A distant memory... |
Brew Master
I just went through the whole epoxy thing. Clean it, degrease it and then grind it. Don't waste time with the floor sanders with the Diamabrush attachment. If your floor isn't PERFECTLY smooth you're wasting time. I went to Hertz rental and got a Husqvarna grinder with cutting heads. I would have saved an ENORMOUS amount of time had I gone that route first. The key is that you want to get up the sealer that is on the floor. Then you want to do a moisture entrapment test where you tape down a 3'x3' piece of plastic overnight to see if moisture wicks up. If it's dry, you're good. If there's moisture you'll want to use a water based bonding sealer. I used a system by originalcolorchips.com. It was not cheap!
BTW, the acid etch does not touch the oil. The oil has to come up with cleaner/degreaser. If you do go the acid route, rather than just rinse, get some baking soda and mix it with water to neutralize the acid. You use much less water when rinsing this way. But again, I'd just do the diamond grinding and call it a day. Last edited by cabmandone; 09-11-2017 at 03:54 PM.. |
Thanks for all the advice.
Since I won't be starting this for about 3 weeks, I will spend the time degreasing, presure washing, repeat. Then I will rent the proper grinder and grind the whole surface. The cement is in reasonably good shape but it's had a lot of oil on it over the years so I will spend extra time cleaning. I will also spend time researching products. I'm open to suggestions - I'm looking for a good product. I probably won't go the Home Depot route as it seems that I have a lot more options when going direct to an epoxy floor manufacturer. |
Brew Master
Main thing you want to be careful of is not just blasting away at the floor with water to remove the stains. You'll actually force water into the pores of the concrete causing water entrapment. Just get a really good degreaser. I used Purple Power from Autozone. I have used this stuff for years on my heavy equipment. If you pour it on straight, it'll actually lift some of the sealer on the floor. Last edited by cabmandone; 09-11-2017 at 04:58 PM.. |
I ened up purchasing a product called Armor Granite. It was not cheap but looks to be a very good, higher-end product.
http://www.armorgarage.com/garage-epoxy-floor-granite-kit.html |
Brew Master
Are you kidding? I've been documenting my whole life.
![]() My biggest hold up, at this point, is the drywall. I can't seem go get anyone to respond to my requests. I've contacted 3 drywallers on Craigslist, each had great pictures of their work and each listed that they have vast experience. Then I get a call back that my job is too big or no call back at all. You've seen my photo on this thread - this job is tiny. If I can't find someone to commit by this weekend, I will order sheetrock and start doing it myself. I can do it but the ceiling is a bit tough when solo. Last edited by Tidybuoy; 09-12-2017 at 02:10 PM.. |
Quit looking for drywaller's on craigslist and just hire a drywall company to come out and do it for you. Drywall is not all that expensive, and the rates are pretty consistent across the industry. Hopefully your walls are framed in such a way that you can install the wall sheet rock in a vertical format.
When I used to install epoxy floors for my clients we would shot blast the old floor. You will not likely find rental equipment for this, but you will find companies that will do it. |
