Banned
water pipe as ground how much is needed
I got a bad leak on my 60+ year old pipe in from the meter
so want to replace the steel 3/4 inch now down to less then 1/2 line with a 1'' PVC line how much steel line in the dirt makes a good ground of the electric service ? I plan on leaving about 18 ft of steel as it is under a concrete slab but not having a direct connection to the main water pipes as the PVC is not a conductor do I need to run a wire to ground to the supply pipe or is the existing 18 ft sufficient for grounding my house ? |
Platinum Member
New home service has 2 grounds. a 20' rebar in the footing, and 2 ground rods (5' each?)
Water lines, water heaters, etc. should also be connected with bonding wire. Use something like this: https://www.homedepot.com/p/Blackburn-Bronze-Ground-Clamp-1-2-1-in-for-Direct-Burial-JD-B1-15/202907610 Can you re-run the 18' over head or in a wall instead? Concrete and steel don't get along, especially in southern florida.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
I'm no electrician so someone else can post more and better info, I'm sure...
Old dog....new tricks..... |
I would drop a ground rod where the power comes in and run another wire to it from the main panel. I doubt you have a disconnect outside. (new code). or run it to the meter base. have pwr company open it up for you.
Banned
have ground on the panel to the steel water pipe
and another by the A/c outside and one for the att phone cable and internets the last two are just bars driven into the dirt the panel ground is a couple of feet inside the garage so connected to 20 ft of 3/4 pipe in the ground under a slab then new PVC pipe to the meter and main water lines is the 20 ft of pipe enough for a good ground for the el panel ? |
canna change law physics
A ground rod is $13 at Home Depot. Buy one and forget about the steel pipe.
https://www.homedepot.com/p/ERICO-5-8-in-x-8-ft-Copper-Ground-Rod-615880UPC/202195738
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Banned
ODD THOUGHT
is the water in a nonconductive pipe a ground ? |
10' of water pipe in ground
two 8' ground rods, minimum 6' apart 20' of rebar in your footing tie all the grounding together or you make the problem worse use #6 wire
Chris the more i learn, the less i know |
Brew Master
I have only one copper ground rod on my service. My outdoor disconnect and my main panel all tie to that single copper ground rod. I'd check code in your area and devise a plan from there. If you can use a ground rod, I'd run a copper ground wire out to it and call it a day.
Kantry Member
No. Best Les
Best Les My train of thought has been replaced by a bumper car. |
Platinum Member
Make Bruins Great Again
Wouldn't using water pipe cause a floating ground problem?
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Instead of leaving 18' of steel line under a concrete slab why not drill under the slab to replace the 1/2 blocked line that you are using now with a clean clear line? Lots of videos on YouTube on how to do this. At some point that galvanised pipe will block completely or rust thru. Why only do 1/2 the job and then have to redo it again in a couple years?
When I built a house in Ontario the regulations called for two ground rods 6' apart. If I was building on solid rock I could attach the ground wire to both ends of the rods and lay in a shallow trench with 6" of covering overtop. Basically 22' of ground wire buried with the rods attached. I built on sand and was able to drive both rods into the ground with a sledge hammer. Here all is required is the ground wire is attached to the supply side of the water meter line.
Bunch of old cars
