beancounter
Posting a picture which probably will appear upside down (from iphone)
beancounter
Top of the door is 8’. Around the perimeter I only have 9’ or so, but as you move to the center of the building I have increased headroom as the roof pitches up from all four sides. I can put the lift at full height with an E class Benz and have plenty of clearance all around
And yes I want to take full advantage of the 12 ' ceiling height so that's why the extended rails . Plus I think it makes for a cleaner looking install .
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Platinum Member
I see that. Full hip roof, center higher.
OP - Don't forget lighting. You probably want to put strips on each side of the lift.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
I really like the ability to aim the lighting where it is needed most . My last garage I had four heads just pointing to my workbench and it was plenty . The rest were pointing to various other areas of the garage . If I remember correctly they were all 4000K lamps so white bright !
Brew Master
The only gripe I have with the liftmaster opener and I don't know why this happens but the one in my unheated barn has some difficulty closing when it gets could out. It's like the down pressure needs to be adjusted when it gets cold. It will go down about 1 or 2 panels and then reverse. If I hook it with a rake and put little to no pressure pulling down, it will close without a problem. The one in my heated shop works flawlessly. I don't know if it's expansion/contraction in the unheated building but it happens every year.
^^^ Ghost in the Machine.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
beancounter
^yes. This is a Revolution 4 post lift. The RFP8 8000lb model.
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
Yesterday I was still thinking about what type of garage doors do I want and what size , I was getting no where . Then I had one of those forrest through the trees moments........... my neighbor is in the garage door business ! I'm new to the area but drive by his house almost daily and he has an advertisement sign in the front yard . I felt like such a dope ! Anyway I called and left a message and he called back last night . Had a nice conversation and he's coming over later today to talk things over .
He suggested a 10 x 9 and a 10 x 10 just based on our conversation so today I will lay the framing out on the concrete with pencil lines and see if I can fit those sizes . I believe I can . I am curious to know his suggestions on conventional panel door vs. commercial roll up . He's apparently well known in the area based on internet feedback and builds custom carriage house doors so he has skills . And being right around the corner can't hurt So I am expecting after today to have a firm understanding of what style/type of doors I will go with and frame accordingly . Thanks for all the advice and pics guys it was helpful .
