from what i've seen of you on other portions of this website, while i have the knowledge you need, i can't find it in myself to help you
Chris
the more i learn, the less i know
Old 12-27-2017, 03:24 PM
canna change law physics
red-beard's Avatar
Looks great, would I have to wind each wire like regular electrical tape or is it applied lengthwise?
Apply just like regular electrical tape and it will eventually fuse together.
James
Red-beard for President, 2020
Old 12-27-2017, 03:28 PM
Team California
speeder's Avatar
I've already gotten the help I need from people better than you. If everyone let PARF determine who they help on technical issues, this board would suck. It doesn't suck.
I'm glad you chimed in, though. I'd have never known you exist, otherwise.
Denis
Old 12-27-2017, 05:25 PM
wdfifteen's Avatar
It's out of the car and there on the bench? I would rather solder in new wire than try to wrap all that in tape.
Old 12-27-2017, 05:41 PM
When your wiring starts snapping the coating when bent, it's time to replace the offending wires with new. I have seen situations where only the end 6"-12" of the plastic insulation has become brittle (and breaks easily), and can either be cut back, or splice in a new wire, or replace all the way from the connector.
I wouldn't try to fix the wires in the picture because the coating will crack in in another place.
Old 12-27-2017, 05:53 PM
Team California
speeder's Avatar
I've never been able to solder worth a damn. Maybe it's time to up my game. They would need to be tiny solders @ the triple plug in order to not have the wires short on each other.
I was planning on replacing all of the insulation on the copper wires, not just in spots. I'm going to examine the patient some more tomorrow. Thanks all!
Well, most all.
Denis
Old 12-27-2017, 06:45 PM
Information Junky
island911's Avatar
I used clear heat shrink tube on my wife's W140.
The clear allowed the non-degraded color-coded sections of the wire bundle to be preserved.
The downside is that HeatShrink is less flexible.
But what do I know, you just called me an imbecile in PARF because you thought I had some thing wrong (but it was you who was wrong.) Nice guy eddie, eh?
Old 12-27-2017, 09:59 PM
Team California
speeder's Avatar
You should stick to technical topics, where you are brilliant, as opposed to politics, not so much.
Denis
Old 12-27-2017, 11:18 PM
GWN7's Avatar
You can use this to dip or paint on the wires but looking at them you should make a new loom with new wire. The resistance built up in the corroded old wires might not make whatever they connect to operate correctly.
Bunch of old cars
Old 12-28-2017, 06:29 AM
cycling has-been
bkreigsr's Avatar
I thought Lucas had a patent on biodegradable wire insulation?
Maybe it expired in the late 40's?
Bill K
Old 12-28-2017, 06:36 AM
