Recommend Cloud Storage?
What do you all recommend for cloud storage?
My daughter wants to get a service that lets her store large files in the cloud, and allows them to be easily retrieved to work on, because her MacBook Air has very limited storage (128 GB). Her MacBook Pro has more (512 GB) but she carries the lighter MBA to class etc. We have tried iCloud Drive but it doesn't do what she needs. It is a sync'ing service, so storing 50GB in iCloud means the same 50GB gets duplicated on the local SSD. We don't have 50GB of room locally. She uses BackBlaze for backup. Is DropBox the default choice? Any others? P.S. It would be good if the cloud storage also worked with her iPad.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? Last edited by jyl; 01-10-2018 at 08:37 PM.. |
Insert Tag Line HERE.....
I used DropBox for my entire college coursework (and since then, i use it for everything else). Works great..
Marc |
You know why they call it “the cloud”? Because if they tried to get you to store your stuff on “some other dudes computer”, you wouldn’t do it.
As we have MS Office on all devices we use OneDrive a lot
Garage Queen
Google Drive allows everything to be stored in the cloud and edited there.
Stephanie '21 Model S Plaid, '21 Model 3 Performance '13 Focus ST, Off to a new home: '16 Focus RS,'86 911 Targa 3.4, '87 930, '05 Lotus Elise, '19 Audi RS3, |
The Stick
On your iCloud Drive choose optimized storage. This will keep only the files you are using locally, well, locally and everything else on the iCloud Drive. Otherwise iCloud drive is a backup and not remote storage.
Richard aka "The Stick" 06 Cayenne S Titanium Edition |
Personally I'd set up my own storage using a old computer, Linux, software RAID and multiple hard drives. Then install synchthing or owncloud on it. |
The Stick
If you are using s Mac you can just setup Apple Server and use it for a file server aka NAS.
Better to use iCloud as Optimized so it will be a remote file server that keeps local copies of only the files you are actively using. You have immediate access to the files you are working on, but still have the rest of your files stored in iCloud instead of locally. Apple is just making it so network speed doesn't effect the files you are actively working on. It may be a bit confusing because it really starts working when you run low on local disk space.
I use google drive for files I expect to be working on on multiple devices. I have a pair of 1T passport drives that I use for cold storage. One is a backup for the other. I also use a Passport to back up my computer using Time Machine. I just don't trust the cloud to keep the only copy of anything valuable.
Bollweevil
Also, can't password protect individual files.
Jack 74 911 Coupe 2.7L - K21 Option - S suspension Last edited by 74-911; 01-11-2018 at 03:18 AM.. |
Recreational Mechanic
Google drive works great for me. I pay the $1.99 per month for extra storage.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
"O"man(are we in trouble)
I use Hillary's drive, very secure and free!
The Unsettler
Cloud storage is fine for sharing and warm or cold backup but less than ideal for hot files.
And you always need an Internet connection which is not always available or robust. She's a student, 1 TB Onedrive plus access to Office suite, ~$1.50 a month. https://products.office.com/en-us/university Alternately, and likely more convenient, expand her storage. IIRC you got her a 2015 15' Retina MacBook Pro. It has an SDXC slot. You can get an all in one solution like a JetDrive https://www.amazon.com/s/?_encoding=UTF8&camp=1789&creative=390957&field-keywords=Transcend%20jetdrive%20lite&linkCode=ur2&tag=9to503-20&url=search-alias%3Daps&linkId=2GC6JD6EO7PLJKQR or use a Micro SD adaptor plus micro SD card. https://www.amazon.com/aluminum-microSD-Adapter-MacBook-onwards/dp/B012F8ALBC/ref=sr_1_9?ie=UTF8&qid=1515676900&sr=8-9&keywords=Nifty+minidrive https://www.amazon.com/Samsung-microSDXC-Adapter-MB-MC256GA-EU/dp/B06XFS5657/ref=sr_1_4?s=pc&ie=UTF8&qid=1515677341&sr=1-4&keywords=micro+sd+card&refinements=p_n_feature_two_browse-bin%3A13203835011 Micro SD vs JetDrive cost is basically a wash but with an adapter you can just pick up more cards for additional capacity or use what you already have even swap files with others by swapping cards. Were it me, I'd take advantage of the student discount on Office 365 and in addition do the micro SD adapter. NOTE: When buying SD cards only buy name brands. If 256GB averages $125 and you see one for $50 stay away. There is no shortage of retailers who take cheap and slow low capacity cards and slap a label on indicating multiples of the capacity they are actually capable of. EDIT: Had some coffee. Those SDXC adaptors also work on Air's although depending on the model it may or may not be interchangeable with the MacBook. The iPad requirement is even more reason to consider Office 365, gives you access to the mobile versions of Office apps. At $1.50 a month it's practically free.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" Last edited by stomachmonkey; 01-11-2018 at 01:54 PM.. |
The micro SDXC card + adapter is genius, thank you. I thought about getting her an SD card to expand memory, but didn't like the way it sticks out. Never thought about the micro route. Thanks!
On Office, I have a family Office 365 and she gets her Office that way. I need to check if I can put Office on her new MBP or if I am maxed out on instances.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
A while ago before I fully retired from Oracle DBA work and evening teaching I was worried about loosing files. I looked at remote or cloud sites and I was not happy with any of them. I went to see the little old Vietnamese lady who runs the small computer store locally and she recommended I do what they did. So I bought a Western Digital 10TB drive and plugged it into a docking station that has place for 2 drives and 3 additional USB connectors. Software came with the dock station and I do a nightly backup. Last year I added a second 10TB drive so now I am set pretty much for even.
At midnight I turn off the LAN connection so there is no chance of intruders and it comes back on at 6:00AM. So far it has been pretty much fail safe and very little chance of stolen files. |
The Unsettler
Plus the student package gets her 2 installs per product, desktop and mobile apps.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Both of my computers have a built in RAID, just two drives that are mirrored. When a drive fails it is easy to swap and it rebuilds the raid. The biggest problem with that is the need for off site storage. In case of a fire, burglar, or tornado or some other event off site is necessary.
I don't worry at all about mudslides, earthquakes, tsunamis, race riots, or forest fires. A grass fire is a very remote possibility. The zombie apocalypse is right up there with bigfoot attacks or extraterrestrials. I do back up the critical files at my business partner's house on a RAID 5 device. And I also use an APP on my cell phone called AirDisk Pro. It makes a connection that works just like a virtual USB drive. I can use WI-FI and copy any file from my Win10 pro computer to the phone. I can easily copy them back off and delete or change them. Since I have my phone with me all the time I have access to critical files at any time. If the FBI can't get into a iPhone I guess it is hacker proof if someone steals my phone. The phone has a code and AirDisk Pro has a password as well.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
It'll be legen-waitforit
Amazon Glacier is good, just not sure of the sync capability
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
Thread Tools | |
Rate This Thread | |
