Driver
'Cause that worked out really well in Ferris Bueller's, right?
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
I think that one's going to be one to watch. It's very unlikely they'll be able to lift that thing back up onto the runway. I guess you're looking at at least 100,000 pounds there, perhaps even more once you figure the baggage weight into it. A 300 ton crane might be able to lift a third of that, once you factor in where it would have to set up. There are bigger cranes, but once you get above 300 tons, you're into cranes that you would have to assemble on site. I still don't think you'd get there... unless, of course, you took everything out in pieces.
Barge-mounted cranes can lift quite a bit more, although you'd have to do some dredging to get one in there. Maybe some documentary crew will film the recovery and we will get to watch it on television some day. |
Russian MI 26 and a few big ass straps and pluck that baby right out of there.
Banned but not out, yet..
Heard this evening cranes are being brought in to lift it out. Probably will use a giant diaper as a sling so all the s*** doesn’t fall out the bottom.
Jeff, retirement is overrated and what’s a few months in beautiful Turkey?
An air cooled refrigerator. ‘Mein Teil’ |
I see you
Jeff what's the scrap value of a totaled jet? Can the structural materials be recycled? Every time I see that picture of the aircraft graveyard I think of all of that aluminum etc just sitting there.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
If anybody has a link to photos of the recovery attempt, please post it here. I've looked around a little and haven't seen anything yet. Probably too soon, who knows... |
What?!?!
We installed a Nuclear medicine camera at a college on the second floor. Elevator is rated at 2,500 lbs, but the gantry weighs 6,400 lbs. Had to call in a rigging company to lift it into a window. In the foreground you can see the white gantry with plastic packaging wrapped around the detectors. The blue and yellow devices are the shipping brackets. That white cart with vertical thingys is a set of collimators that get switched out depending on the scan type. That set weighs about 600 lbs and mates to the detectors and rolls into place. Site Diagnostic Imaging Managers know this stuff, but facilites and construction guys are shocked to hear the weight involved. A CT scanner weighs in at about 3,000 lbs, but MRI can be 13,00 to 24,000 lbs! ![]()
running shoes, couple tools, fishing pole 1996 Subaru Legacy Outback AWD, 5speed 2002 Subaru Impreza WRX, 5speed 2014 Tundra SR5, 4x4 1964 Land Rover SII A 109 - sold this albatross |
Team California
That's amazing, Don.
My problem solving skills would have been to install it on the first floor.
Denis "It won't interfere with the current building. It'll be near it but not touching it." -Grifter in Chief, July of 2025 |
Control Group
Magnets are heavy, go figure
She was the kindest person I ever met |
Some are much heavier than others....
Control Group
Especially the ones that make all the hydrogen atoms in your body spin the same direction.
I was referring to the variations in machine design. Field strengths vary, the type of magnets vary... but you know all that. It's fun to install machines like that, because few hospitals were well designed with easy access in mind and hospital administrators always want to put things in the worst possible place.
JR |
So, was Richard Hammond flying and will this be on The Grand Tour also?
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
Driver, not Mechanic
Put some balloons underneath and let it slide and float on the water... Hahahaha
We actually use that aircraft graveyard as kind of our own giant "pick'n'pull" wrecking yard. Much of the time we wind up repairing out of production aircraft, and our only source for parts is that graveyard. When the 747 changed wings on the -8 variant, for example, we wound up down there pulling upper and lower outboard wing skins for a -400 repair in South Africa, because that version was out of production. No one stocks those kinds of parts, not even us.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
Slackerous Maximus
You'll have to watch an ad, but there is video of the lift here:
Passenger plane lifted away from cliff edge after Turkey runway incident
2022 Royal Enfield Interceptor. 2012 Harley Davidson Road King 2014 Triumph Bonneville T100. 2014 Cayman S, PDK. Mercedes E350 family truckster. Last edited by HardDrive; 01-18-2018 at 05:48 PM.. |
Smallest 747-800 ive ever seen!
Looked to be in remarkably good shape considering the circumstance. What’s Higgins think, repairable? |
You do not have permissi
I once got on a plane in Europe where there was a 12 to 18 inch deep dent right before the left horizontal stabilizer. Ugly.
Looked like someone backing up the plane had caught it on a doorway and ripped the fin off. And then someone else stuck a new fin on and certified the tube to go. No problems with the flight actually. I forgot the altitude but it was a regional thing and probably not above oxygen even. |
It looks like it all worked out. They were able to approach close enough with the big boom cranes without having to do anything extraordinary with the underlying footing. Easy peasy.
Next step is a survey team to assess damage. From there, a repair estimate will be offered, and it's then up to the airline and their insurance carrier to determine whether or not it will be repaired. You never know... I've been in on the repair of far worse. It might look bad, what with the one engine sheared from its mounts and all of that. The thing is, though, it's supposed to do that to mitigate damage to the strut and attendant structure. We provide shear pins that are meant to let go so that kind of thing just tears off. Same with the gear, it can get pretty beat up, to torn completely off, and everything that it hangs from is pretty "easily" (relatively) replaceable. They'll fix it and have it flying in no time.
I wouldn't want to be the guy that put the straps in place.
Guess they could secure the plane from sliding from the tail section, still. They did place the crains well back from the edge. Would have thought it was a heavy lift at or near full extension. Nice job. Cheers Richard |
