Cars & Coffee Killer
Coding Humor
Came across this in some java code today:
public void meLoveYou(long time){ }
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
I have a UDP joke, but you probably wouldn't get it.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Slackerous Maximus
One of my colleagues and I have a running contest to see who can slip the most absurd parameter or method names past our review process. She recently put in parameter called 'which_one' that is a boolean operator. I put in a method that counts daemon processes called 'time_to_count_zee_daemons'.
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
A QA engineer walks into a bar and orders a beer.
Then he orders 0 beers Then he orders -1 beers Then he orders 32769 beers Then he orders asdf beers
Takin' hard left turns
There are 10 kinds of people in this world: those who understand binary, and those who don't.
A wife asked her coder husband to go to the store to by milk. And, she said, if they have eggs, by a dozen. He came home with 12 gallons of milk. Why did you by 12 gallons of milk, she asked. Because they had eggs, he replied.
Charlie 1966 912 Polo Red 1950 VW Bug 1983 VW Westfalia; 1989 VW Syncro Tristar Doka |
White and Nerdy
Slackerous Maximus
canna change law physics
In the world of Gas Turbine Controls programming, the IEEE designation for cranking motor is "CR". I was re-programming the control system to control the turbine startup acceleration based on the motor power based on the motor current. The analog control parameter was:
CRAMPS And since 1992, it is still there.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
There are two kinds of people in this world: those who can extrapolate from incomplete data.
B4i4qru/18qtπ ?
Mark '88 Carrera GPW Sunroof Coupe '82 SC Targa (RIP) |
Super Moderator
Along this same line... A good friend of mine works for the Chicago water reclamation system. (aka toilet water)... Over certain aeration areas they collect off-gassing to burn to get rid of the smell. The resulting air goes through a pipe to the plant. The engineers that designed this system named it the Foul Air Recovery Tube knowing that all pipes are labeled with abbreviations. So through at least one Chicago plant - there is a pipe labeled F.A.R.T. running through it carrying sewer gas.
Super Moderator
A man flying in a hot air balloon suddenly realizes he’s lost. He reduces height and spots a man down below. He lowers the balloon further and shouts to get directions, "Excuse me, can you tell me where I am?"
The man below says: "Yes. You're in a hot air balloon, hovering 30 feet above this field." "You must work in Information Technology," says the balloonist. "I do" replies the man. "How did you know?" "Well," says the balloonist, "everything you have told me is technically correct, but It's of no use to anyone." The man below replies, "You must work in management." "I do," replies the balloonist, *"But how'd you know?"** "Well", says the man, "you don’t know where you are or where you’re going, but you expect me to be able to help. You’re in the same position you were before we met, but now it’s my fault."
To be fair, I did remove the contents of the method.
You do not have permissi
Office work is like using using the restroom. It ain't over until the paperwork is done.
