Ribeye steak help fast....
Got a couple of nice ribeye steaks from my son.
I've got potatoes in the oven right now at 425*, been in for half an hour already, on a big skewer and wrapped in foil, but not real tight.
Can I put the steaks on the ribbed cast iron and stick them in for say 15 minutes then sear them on my other flat cast iron pan on top of the stove?
Scott
'78 SC mit Sportomatic - Sold
Old 03-26-2018, 04:14 PM
NO.
How thick are the steaks. Cook them a 250 for 20 minutes per inch and a half thick. Remove from oven then sear both sides in a scorching hot cast iron pan for 3 minutes a side.
Let rest 5 minutes. Perfect medium rare all the way thru
1982 SC
Old 03-26-2018, 04:19 PM
vash's Avatar
Disclaimer: I have never used a grill pan.
I would put that pan in the oven to get hot. Rocket hot.
Blot that steak dry. Salt/pepper liberally and drizzle w oil. Then sear one side. Flip the steak and pop the pan into the oven.
I bet it takes 6 minutes for med rare. I do that press test with my finger.
poof! gone
Old 03-26-2018, 04:22 PM
crustychief's Avatar
I agree with Cd. I would also use the ribbed pan for the searing.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
They're only an inch thick. So 15 minutes at 250 should do it?
Scott
Old 03-26-2018, 04:23 PM
OK, I'll do a pan sear with the ribbed pan, then put them in the oven for a bit to finish as it's already at 425*.
That's more like how I do salmon so it should work.
Thanks guys.
Scott
Old 03-26-2018, 04:25 PM
It'll be legen-waitforit
stealthn's Avatar
No BBQ?
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 03-26-2018, 04:30 PM
craigster59's Avatar
Vash has it right. Heat pan in oven, seat one side, flip and toss in oven to finish. Foolproof.
Old 03-26-2018, 04:57 PM
Recipe here... https://www.thekitchenwhisperer.net/2012/07/15/better-than-restaurant-quality-new-york-strip-steaks/
Old 03-26-2018, 04:59 PM
(the shotguns)
berettafan's Avatar
searing should be on a flat pan, not ribbed.
a bit late now but I'd sear one side, flip then put the pan with the steaks in the oven with maybe a pat of butter on each.
Old 03-26-2018, 05:02 PM
Information Overloader
One of these days I'm gonna get a thickish slab of granite, put it in the oven on self-clean mode for a while, pull it out of the oven somedamnhow and plop a hunka raw, room-temp meat on it like I saw in a movie once.
I wonder if that'll work.
Old 03-26-2018, 05:06 PM
Senior Member
Superman's Avatar
It's pretty hard to mess up a ribeye.
Mocha 1978 911SC. "Coco"
Old 03-26-2018, 05:11 PM
Eric Coffey's Avatar
Originally Posted by Cdnone1 View Post
NO.
This (reverse sear).
Except I typically go 30-35min in the oven @ 250, then only sear for 30sec to 1min per side in hot cast-iron skillet.
Less of a "well done" outter ring that way (mid-rare pink all the way through, not just in the middle). YMMV...
Old 03-26-2018, 05:12 PM
Ribeyes?
Old 03-26-2018, 05:16 PM
Thanks for the help all.
I've been practicing on our salmon dinners.
This turned out pretty good. Helps to have a good piece of meat to start with.
Here's how it turned out:
Leftovers should heat up just right.
I didn't want to attempt to use the bbq as it's hard to keep the heat in it when it's windy out, which we've been having this afternoon.
Got some filets to cook up too, but those will be next week or so possibly.
Scott
Old 03-26-2018, 05:20 PM
Filets, Scott? Wow!
Old 03-26-2018, 05:46 PM
vash's Avatar
I rarely cook smelly food indoors now. This was tonight’s dinner. Someone mention salmon? my carbon steel pan is perfect for this since it kinda cools off faster than cast should it get too hot. It’s finally seasoning up properly
I got the pan rocket hot. Popped in the fish and closed the lid. I did open it up a few times to baste the fish with fat. And to pour on some capers. And flip once.
poof! gone
Old 03-26-2018, 06:08 PM
Let me fix that for you.
Old 03-26-2018, 09:26 PM
T77911S's Avatar
personally I never would have bought steaks that look like that.
marbling is not bad but there is very little of the "cap" on the left one and NONE on the right one.
that's the best part of a rib eye.
I also never cook steaks by tame.
that's just me.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-27-2018, 03:12 AM
"by tame"?
I don't know that technique.
down to jap bikes that run and a dead Norton
Old 03-27-2018, 03:20 AM
