Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Primer on paint chip area won't stick
I have an ~1/8"x3/8" chip that has some bare metal, primer and paint in it.
I did a light sanding with 600 wet.
I tried using rattle can Krylon (I think) Zink Primer but I am able to wipe primer off after more than 24 hours. I would still prefer to spray on the primer and paint.
I was in compliance with the temp/humidity spec'd on the directions.
I tried to find some Wurth Rustop Primer suggested in PP forums but couldn't find it... maybe they changed the name?
What am I doing wrong?
If need be, where can I get a small amount of a more suitable primer?
On a related note, can i get a small spray can of GP White?
any help will be greatly appreciated! Thanks.
Old 12-16-2009, 10:04 AM
I feel the luv!
I feel the luv!
Old 12-17-2009, 03:34 PM
dkbautosports.com
962porsche's Avatar
i don't use spray cans ! but i think a 600 cut is to fine for even spray can primers . most jobbers (auto paint stores) will put there colors in a spray can for you .
Old 12-18-2009, 04:27 AM
moneymanager's Avatar
There hasn't been any silicon spray here has there? Nothing will stick to silicon.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 12-18-2009, 07:33 AM
The 600 came from the rather lengthy procedure I found on PP forum. Can I resand with something more suitable, say 400?
So maybe your saying silicon in what may be the original/current primer still left in the chip zone as well as my GP white on the chip edges, guess I'll never know that for sure.
Should I take all the chip area to bare metal primer and hope the new paint blends/sticks well with the surrounding GP White?
Didn't think fixing a paint chip would be so difficult, wonder what a shop would charge?
Thanks.
Old 12-18-2009, 08:33 AM
There won't be silicon in the paint unless it somehow got there by accident. Not likely in a spray can. I was talking about silicon spray somehow getting on the spot you are sanding.
jhtaylor
santa barbara
Old 12-18-2009, 09:09 AM
P21s and 70% Iso Alc... should have been sily free and clean enough to operate on.
As usual... I have more to learn than years to live.
If I can't fix a frigin paint chip wadda my chances of rebuildin the engine when it comes time
thanks.
Old 12-18-2009, 04:47 PM
Agree it should be clean. Though I had the same problem once and nothing, except removing the metal by sanding, finally let the paint stick. BUt I'm guessing you face some other issue. Good luck.
jhtaylor
santa barbara
Old 12-18-2009, 05:31 PM
"removing the metal", did you mean primer???
Old 12-20-2009, 09:55 AM
I couldn't get the paint to stick to a bare spot with primer all around it. So I sanded thoroughly, took all the primer off and some metal, and it worked. There are silicon removers around but I'm not sure they work well. A lot of people have had this issue before. But unless you or a previous owner sprayed silicon on the spot you are likely facing some other issue.
jhtaylor
santa barbara
Old 12-20-2009, 11:41 AM
