Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Rick
paint code 1970
Does anyone know where the paint code is found on the body for a 1970 911 european specs? I can find the serial number but not the paint code.
Rick
1970 911 E purchased in Stuttgart in 1973
Old 02-28-2010, 04:12 PM
HarryD's Avatar
You should find a plate on the driver side door post. Looks like this:
The number stamped there is the color code. You can look it up here: Porsche 911 Farbdatenbank
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 02-28-2010, 06:55 PM
Rick
Harry,
Thanks! the reason that I was having difficulty is that the chassis number and engine number translate to a 911 E Coupe Karmann with the engine in the right range, but I never could find a number that matched the 1970 color numbers. The color code stamped on the door post plate is 23-23-H, which is a 1971 color - blood orange. This clears up another mystery as I thought it was signal orange, but the pictures never looked like mine. I guess as mine is number 528 of 667, it could have been built late in 1970 and actually used the 1971 paint code.
Do you know if I can write / email the factory with the serial number to get all the build information like gearsets or options?
Thanks.
Rick
Rick
Old 02-28-2010, 10:27 PM
HarryD's Avatar
The best you can hope for is to order a Certificate of Authenticity (Certificate of Authenticity - Owner Services - Porsche Service - Dr. Ing. h.c. F. Porsche AG). If you search here, it is of variable accuracy.
Harry
2020 MB E350 4Matic
Old 02-28-2010, 11:23 PM
