Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Bird. It's the word...
Fishcop's Avatar
Originally Posted by Series900 View Post
run, you can find so much better to start with and if your emotional attachment is the color, paint another one! unless that had some unique vin provenance, its parts, rusty worn out ones at that.
You now have the opinion of a proper expert!
If it's not your grandfather's "werks" ST/R RUN!!
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 12-12-2010, 04:37 PM
robmog's Avatar
if you want a # matching concours masterpiece, find another.
but since you already have a nice engine it might be worth saving.
the problem with longhoods is as they increase in value, most are unwilling to modify.
sadly this car is in poor shape and not worth restoring as a collector, but as a race car, maybe.
the floor and tunnel can be repaired, how are the suspension points?
the front are an easy fix but the rear torsion bar tube is a difficult repair.
and double check the longitudinal repair, if solid with good suspension points, i'd say go for it.
bob
1972 E pos
correction: expensive pos
someday....
"shut up and drive!"
Old 12-14-2010, 06:58 PM
Brando
quattrorunner's Avatar
I'm trying to run. I found rust inside the longitudinals. If I can't sell it, maybe I'll work it into my life but I'm not too happy about having it today. We'll see tomorrow.
Old 12-14-2010, 09:01 PM
Brando
And found that a previous owner patched the rockers with bondo at some point. wow.
Old 12-14-2010, 09:03 PM
onboost's Avatar
Sometimes some must die so that others may live!!
Run Forrest!
RGruppe #180
Old 12-15-2010, 07:20 AM
The challenge to do something "just because it can be done" is often tempting, but in this case, outside of special provenance, I just don't see the upside. Yes, it can be done, but if you want a race car or something, you will be streets ahead finding an SC shell/roller and building that up. To do this car right, the cost (and time especially) will be high. The link posted by sfoster13 is very instructive (and its worth noting that that shop had everything, including a Celete). How much of that car did they actually keep? This car may even have less good metal.
I have yet to see one of these older cars where there wasn't a whole lot of other rust issues than were initially apparent. It sounds like you are starting to find them (i.e. the rockers).
You are the one in the best position to judge though, and good luck whichever way you choose!
Old 12-15-2010, 07:58 AM
Tired Member
DaddyGlenn's Avatar
Part it out and crush the remainder
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 12-15-2010, 01:06 PM
Brando
I ran.....I ran so far away.
Some one else is going to do something with it now. I'll keep my eye open for something else. Someone with a good roller?
Old 12-19-2010, 01:33 PM
