Scotiagreg
Paint name/code
I think this car is Gulf Orange. But... maybe it's Tangerine (Blutorange). Can anyone confirm the color and the code? Much appreciated. Greg
1963 356B, 1968 hotrod 912/6 1985 Carrera, 1992 Carrera 2 Targa 2005 Boxster S, 2017 Macan S |
dkbautosports.com
if there was not a color change to the car you can take the vin number and call the porsche dealers parts department and they will give you the color code and name . if not i could check into it and get the info for you when i get to my shop .
Scotiagreg
I should have mentioned that this is not my car. I would like to paint my car in this color. I have no idea where this car is located, I am merely an admirer.
Its Gulf Orange code 019
dkbautosports.com
yep i would say its gulf orange too code 019 from 1973 to 2005 or for 1972 only the code would be 061 .
Scotiagreg
Gulf Orange 019 has been ordered and will be sprayed in my interior, engine bay and boot after strip, media blast, primer, seam sealer etc. It a DIY project over the holidays. Then it's off to a real body shop to do the exterior. Thanks for the confirmation on the color and codes.
Scotiagreg
Holy Cow
Man!!! this is orange. Does it look like Gulf Orange to you? I am trying not to loose my nerve. This is supposed to be 019 Gulf Orange. Looks like a hunting cap to me but it is under florescent lighting.
For early cars, you can look here:
Porsche 911 Farbdatenbank and here: Glasurit Color codes and samples for 1966-
dkbautosports.com
it looks like 061 / 019 golf orange to me . i would not say the car on the top of this posting is 116 / 1414 signal orange . signal orange is a lighter color orange . if your trying to match a color from a photo for get it ! thats like a dog chasing its tail . if your thinking its to bright of an orange than i will have to ask what color ground coat did you use ? how many color coats were applied ? if you used a white ground coat with only two color coats it will look brighter than the same color sprayed over a very light gray with 3 or 4 color coats .
Scotiagreg
The interior shot is 2 coats over black rock guard. i think it will be fine once the car gets stripes, tires, trim etc. Looks like this later model which I like very much Thanks for the input. Greg
Racer
You might want to look at this post:
Rennlist Discussion Forums - View Single Post - Need paint code from Orange GT3RS and this thread: http://forums.rennlist.com/rennforums/997-forum/331888-do-you-know-what-the-colour-code-is-for-pure-orange.html Scott |
